Forum: Carrara
Subject: looping a poser walk in Carrara....
spinners opened this issue on Mar 18, 2006 ยท 7 posts
spinners posted Sat, 18 March 2006 at 3:50 AM
importing low rez versions of animated poser characters in to carrara works (lots of background people are needed)....now i need to loop their walking..... so far as far a i can tell, i have to do the complete walk cycle in poser (which can be up to 12 seconds x 20fps....) isnt there a more sophisticated way?
Jconxtc posted Sat, 18 March 2006 at 1:22 PM
umm..not that i know of, maby someone smarter than i knows... Are you using carrara 5 or 5 Pro? cuse in pro their might be a real good way using the graphs, but ive never realy played around with that.
spinners posted Sat, 18 March 2006 at 1:26 PM
using 5 pro whats the idea?
ominousplay posted Mon, 20 March 2006 at 1:49 PM
Hi, I'm not sure how detailed you are trying to make the walk, but if it is just one foot after the other, arm swing, head bob, hips tilt, then just either: Import just two steps and loop it in Carrara - shouldn't be 12 seconds for two steps. Or, import the poser figure with bones but no animation, make your own 2 step walk, and loop. Good luck, hope this helps. R
Never Give Up!
spinners posted Mon, 20 March 2006 at 10:34 PM
i need very little detail.....is there a "looping mechanism" in carrara...something automatic. as opposed to repeating the walking motion on the timeline every second? havent go to the "bones" aspect of poser....(still the beginner)
ominousplay posted Tue, 21 March 2006 at 2:48 PM
not sure about looping, but I do know you can select the key frames for your two step walk and repeat them as many times as you need. I do know of some repeated functions for swinging, spinning, etc. - check it out in browser, motion.. maybe. R
Never Give Up!
ren_mem posted Wed, 22 March 2006 at 3:51 AM
There are different tweener options also, would any of those help???
No need to think outside the box....
    Just make it invisible.
