Forum: Fractals
Subject: UF mask: help!
Kid_Fisto opened this issue on Mar 18, 2006 ยท 5 posts
Kid_Fisto posted Sat, 18 March 2006 at 7:49 AM
Help! can anyone tell me how to make the black area of a mask mapping in UF Transparent? how do you do that? thanks, craig
mountmous posted Sat, 18 March 2006 at 8:33 AM
Make the solid colour transparent, I should say. Click on the black bar and set the opacity to 0. If that doesn't do the trick go the outside colouring and set the opacity of the solid color there too at 0. Sometimes the outside colouring has another "color"bar somewhere, so check that as well. And if that's not enough maybe it's in the inside colouring. Anyway: check the solid color for it's opacity. Good luck. Yvonne
tresamie posted Sat, 18 March 2006 at 5:25 PM
Hi Craig, Maybe you could attach a file with just the layer you are having trouble with so we could see which of several problems are involved. ~Vivian
Fractals will always amaze me!
ulliroyal posted Sun, 19 March 2006 at 6:12 AM
  1. Activate the Mask Layer.
  2. On the gradient window make the opacity part active.
  3. In the upper left corner of UF say Gradient > invert.
Message edited on: 03/19/2006 06:15
Message edited on: 03/19/2006 06:17
Kid_Fisto posted Sun, 19 March 2006 at 9:05 AM
thanks guys, i worked it out. the solid color needs to be transparent.
