Subject: Help! Mike's collar inverted!
kevinchn opened this issue on Mar 30, 2001 ยท 9 posts
kevinchn posted Fri, 30 March 2001 at 8:04 PM
Help me please, it seems that Michael's dress shirt always have the problem of the collar inverting inwards. I dialed the unbutton all morph and the open left/right to 0.5. I also tried using the individual unbutton dials but the collar still remain pointing inwards. Can someone tell me what went wrong? Thanks!
wyrwulf posted Fri, 30 March 2001 at 8:25 PM
I just tried your .5 settings and it looks fine for me. Maybe the geometries RSR for the shirt is corrupt. Shut down Poser, delete the Geometries RSR, and try again. Poser will build a new RSR when you load the shirt. Don't delete the RSR in the characters folder.
JKeller posted Sat, 31 March 2001 at 1:42 AM
Make sure you use the full body morphs for the unbutton dials and not the ones on the individual body parts. Makes things much simpler.
kevinchn posted Sat, 31 March 2001 at 9:16 AM
Thank you for your advises. However, it still don't seem to work. I tried deleting the rsr geometry file as Wrywulf suggested but the collar still fixed inwards. But thanks anyway, I appreciate the help:)
JKeller posted Sat, 31 March 2001 at 12:12 PM
From that picture, the collar actually looks fine, but it looks like you are using too many, overlapping unbutton morphs. Just use the fullbody 'unbutton all' morph (keep all the unbutton 1, unbotton 2, etc all set to 0.000) and I am sure you will get much better results.
BlueRain posted Sat, 31 March 2001 at 10:09 PM
See what you went and did?,You made him non-dorky and the poser females ravaged him!
kevinchn posted Sun, 01 April 2001 at 7:45 AM
Actually, I only used unbitton all and open left/right to 0.5. that's all. The file is probably corrupted I guess..
wyrwulf posted Sun, 01 April 2001 at 1:48 PM
Try deleting all references to the shirt in your Poser directory and then reinstall. I would redirect the installation for the clothing pack to a temporary folder, then pick out just the stuff for the shirt and put them where they belong in the Poser directory. If that doesn't fix it, contact Daz on Monday. They are very good at taking care of problems.
kevinchn posted Mon, 02 April 2001 at 6:08 AM
Thanks a million!
