Subject: Cutting up a mesh
grahamjames opened this issue on Mar 20, 2006 ยท 2 posts
grahamjames posted Mon, 20 March 2006 at 5:20 PM
Hi, is there a program around that would allow me to import a mesh, like a catsuit, and cut it up into sections to make a bikini or a pair of shorts. I am asking because I have just noticed the 2nd skin program and am thinking of buying it. If I made an object and CR2 of the suit it would be cool to then use that to generate more clothing. I know that it would be possible to do it with trans maps but on Poser 4 that means you can't use highlights easily because it then looks like the transparent portions are plastic coated.
PhilC posted Mon, 20 March 2006 at 6:21 PM
Try using the Poser Grouping tool. Select the polygons you want, then click the spawn prop button.
