Forum: Vue
Subject: Why is Vue so slow?
dadt opened this issue on Mar 23, 2006 ยท 18 posts
dadt posted Thu, 23 March 2006 at 7:52 AM
I loaded a wavefront object and it seemed to take forever so I did some comparisons using the same object loading into empty scenes.
Vue 5I ---- 293 secs
Bryce 5.5 ---- 25 secs
Poser 6 ---- 18 secs
Carrara 5 ---- 7 secs
Why such a large difference?
Message edited on: 03/23/2006 07:54
garyandcatherine posted Thu, 23 March 2006 at 12:02 PM
Oh my gosh!!!!!!!! I can't believe it takes so long for you. I have absolutely no idea whats up. I do have a suggestion, try doing a comparison with another obj and compare the results. It could be that just "that model" has issues with VUE where others might not.
GPFrance posted Thu, 23 March 2006 at 2:14 PM
Look into Vue's rendering-, atmosphere- and sun/lights-settings, and adjust those to the quality you want to obtain. It is really "easy", to have Vue render a "simple" object in many, many hours... ;-) Depends on what one ask's it to do... :-) Look at Peggy Walter's "guidelines" http://users.tns.net/~mwalter1/
dadt posted Thu, 23 March 2006 at 2:16 PM
The problem was not in rendering but in loading the object into Vue.
GPFrance posted Thu, 23 March 2006 at 2:28 PM
Ah sorry, I misunderstood. I got no problems to load, but I observed that same items take a little longer in .obj format, than in 3ds format. I thought that it might have something to do with a more complete texture transfer ? I don't know.
dadt posted Thu, 23 March 2006 at 2:36 PM
Its just a plain OBJ with no textures, but I've tried other similar objects and they load quickly so it must be a problem with the particular mesh.
GPFrance posted Thu, 23 March 2006 at 2:45 PM
I would be curious to know, if you'd export this one from Vue to .obj, and back again into Vue, how much time the second version will take to load, and if everything will be there...
diolma posted Thu, 23 March 2006 at 2:56 PM
I have absolutely no proof of this, just a gut feeling...
I suspect (in fact I'm almost certain) that Vue converts all "foreign format" imports to its own internal format (.vob, probably). There could be a difficulty with the transformation from .obj to .vob, which requires more time to resolve, especially if .vob is a format which differs substantially from .obj, 'cos of emphasis on some sort of performance optimisation (possibly in memory used)...
Or not...
Cheers,
Diolma
Edited to add the obvious: Once a .obj has been loaded (and if you're intending to use it again in a different pic), save as .vob... But you knew that already, I suspect..
Message edited on: 03/23/2006 14:58
dadt posted Thu, 23 March 2006 at 3:02 PM
I've just tried exporting it as OBJ and Vue appeared to lock up. After 5 mins there was no apparent movement of the progress bar although it was using 98% of processor time.
dadt posted Thu, 23 March 2006 at 3:08 PM
Diolma- I think you are right about Vue converting imported objects,this one has 19k polygons but Vue reports it as having 136k.
diolma posted Thu, 23 March 2006 at 3:18 PM
19k to 136??? Sheesh that's about errm... (excuse me while I fire up calculator)...
A 7-fold expansion (plus a tad)..
Wonder if Vue is doing a "smoothing" exercise on import?...
Cheers,
Diolma
Message edited on: 03/23/2006 15:24
dadt posted Thu, 23 March 2006 at 3:25 PM
I don't think it needs smoothing, its only a sphere!
dadt posted Thu, 23 March 2006 at 3:47 PM
The plot thickens. I made a similar object but much simpler with only 14 holes. The unsmoothed mesh was 180 polygons and in Vue was also 180. After smoothing the mesh was 720 polygons but in Vue was 960. After smoothing again it was 2880 polygons but in Vue was 4320. I can't see any logical reason for this.
diolma posted Thu, 23 March 2006 at 4:19 PM
Hmmm... Interesting (if only for "Why The F*k" purposes...) Does Vue have a "smoothing angle" that kicks in? That might account for it. If I have time tomorrow (and if I remember), I might frt about with this, starting from a cube, then smoothing etc. til the poly count differs... It'd be nice to know... (Unless, of course, anyone more knowledgable chimes in..) Cheers, Diolma
Trelawney posted Thu, 23 March 2006 at 9:10 PM
Hi dadt I don't know if you own Poser or not, but if I have any issues importing other formats to Vue, I import them to Poser 6 instead, save as .PZ3, and then import that to Vue. Not a 'fix' I realise, but if you can get the object into Vue ok, then you can save as a VOB, and then hopefully find that will load a great deal faster for you, Kind regards
GPFrance posted Fri, 24 March 2006 at 3:58 AM
If Vue blocked on exporting the data to obj, there seems to be a problem with the mesh and Vue's calculus...
I had problems with preceeding versions of Vue, with hollow or other complex objects. Especially, when the thing was mathematically exact, symmetrical, and centered at zero, so many opposed points just differed by the +/- prefix, but not in ciphers. Came up with lacking faces, holes, had points at 32thousand (seems to be some kind of infinity). But mostly, it just ran into a wall and blocked.
Haven't had such problems lately (unchecked "resize and center").
I encounter difficulties when importing complex dxf architecture into Vue. Those I pass over to the free Cinema4d v.CE6, where I can check for errors, and export via 3ds to Vue (ignoring the alert for out-of-date textures).
Up to now, that worked clean and fast, here.
chippwalters posted Sat, 25 March 2006 at 2:07 AM
"The plot thickens. I made a similar object but much simpler with only 14 holes. The unsmoothed mesh was 180 polygons and in Vue was also 180.
I can't see any logical reason for this."
I'm guessing Vue is probably triangulating all polys greater than 3 sides, as it does when importing objects, as triangles are guaranteed to be coplanar. And since it appears there are a number of concave polys, it is taking it's time.
GPFrance posted Sat, 25 March 2006 at 3:21 AM
Hi, chippwalters ! I think you hit that one - sounds logic !
