Forum: Carrara
Subject: Comments/critiques?
rhamilton opened this issue on Mar 31, 2001 ยท 17 posts
rhamilton posted Sat, 31 March 2001 at 1:11 PM
This is a character I've created for an animation I'm trying to do. Modelled mostly in Carrara's vertex modeller with some (staff, scabbard, swordblade, and boots) started in the spline modeller and touched up in the VM. posed and rendered in Poser.... I only wish Carrara had "Bones"! I'm still working on the skin texture... using UVMapper and PhotoPaint
rhamilton posted Sat, 31 March 2001 at 1:20 PM
this is the walk cycle I created for her.
rhamilton posted Sat, 31 March 2001 at 1:21 PM
no poser character.... created entirely from scratch
twillis posted Sat, 31 March 2001 at 4:20 PM
Well done.
servo posted Sat, 31 March 2001 at 4:34 PM
Very nice work.
tjs61822 posted Sat, 31 March 2001 at 4:52 PM
I'm impressed! But if you want a critique, here you go: - You might want to darken the center of the belly button to give it more depth. - There seems to be a "knot" on the outer part of the right shoulder, but it is not as prominent in the walk animation (nice movement by the way). - The wrist might need to be a little thicker. Of course this is just my personal opinion. Overall it's a great character. I love the clothing. How long did it take to model?
rhamilton posted Sat, 31 March 2001 at 7:42 PM
time to model..... the model itself took about a day (removing time wasted to crashes within Carrara) putting the model into poser took a while, this was my first attempt at making a model for poser.... this took about a month (about half a dozen attempts at setting the character up right within poser) I'm sorry I can't give a more accurate time estimate... I have a couple of things on the go and tend to constantly switch back and forth between them
Lynne posted Sun, 01 April 2001 at 8:06 AM
OH MY! If this can be done in Carrara...I'm glad I have it and can't wait to reach your level of skill! Would LOVE to see some shots of some figure parts unfinished inside Carrara work area. I'm so glad to know that this CAN be brought into poser. Please keep updating your progress. This is a very interesting figure. Love the freckles.
litst posted Sun, 01 April 2001 at 9:42 AM
Wow ! This ones's a very nice model ! Like Lynne, i'm curious to see it inside Carrara . Could you please post a scren capture of the lo-poly version ? litst
rhamilton posted Sun, 01 April 2001 at 10:55 AM
I created this character in parts and then assembled later here is the body
rhamilton posted Sun, 01 April 2001 at 10:56 AM
here's the head
rhamilton posted Sun, 01 April 2001 at 11:03 AM
and the hand... the clothes were created by taking the subdivided body and using the add thickness function
litst posted Sun, 01 April 2001 at 2:43 PM
The hands are very good, that's typically the kind of thing were i could spend an entire day on ! ;) Were the fingers made by extruding, adding thickness, lofting ? litst
rhamilton posted Sun, 01 April 2001 at 10:53 PM
fingers were made by extruding... but I did have a problem with Carrara when creating them... for some reason the vertex modeller duplicated all the vertices in the fingers and the knuckles. This resulted in a second layer that I couldn't see but would cause havoc anytime I tried to link or weld any vertices. I couldn't figure out the jump in polycount until I grabbed a vertex and pulled... the second layer came off like peeling off skin. Very strange... not sure what cause it and it hasn't happened again. I just hope it doen't happen to one of my high poly models!
litst posted Mon, 02 April 2001 at 11:35 AM
I've had those file size jumps before ... Weird ! It doesn't happen often, but when it happens, it's really pervert : you can guess your file is corrupted, unless you check its size . Or if you pull vertices like you did . At least we know more about this bug now : according to your experience, it comes from an unwanted duplication of the vertices, right ? By the way, how did you get rid of it ? Did you weld the model with a low tolerance ( 0.01 or something like that ) ? litst litst.@freesbee.fr
rhamilton posted Mon, 02 April 2001 at 1:18 PM
I tried welding, but that only messed things up more.... peeling off the duplicate vertices worked in this particular instance
Stacey posted Tue, 03 April 2001 at 5:26 PM
WOW I am so glad that you posted this. It has really inspired me and I already see some things to work on/fix in my model techniques. Thanks
