lululee opened this issue on Mar 28, 2006 ยท 6 posts
lululee posted Tue, 28 March 2006 at 10:01 AM
Is there a utility to gather Poser textures into 1 folder for import into other apps as an obj file? Cheerio lululee
geoff1 posted Tue, 28 March 2006 at 10:33 AM
Hi I use a program called Babel which from memory came from www.castironflamingo.com There is a program there called Grouper which may be a later version. Anyway this program does a great job of collecting and transferring textures except for the main figure which is easy by hand. It takes its input from the pz3 file. When I get home I'll check it out and if nobody else has supplied the answer I'll add it to this thread.
stewer posted Tue, 28 March 2006 at 10:39 AM
It comes with Poser 6 - look in the Python scripts, "Utility Funcs/Collect Scene Inventory".
lululee posted Tue, 28 March 2006 at 11:01 AM
Thanks so much stewer. It works perfectly. cheerio lululee
barrowlass posted Tue, 28 March 2006 at 4:31 PM
thanks stewer - didn't know about the P6 script - managed my first export into Vue - couldn't believe how easy it was.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
yarp posted Tue, 28 March 2006 at 10:41 PM
P3dO pro does this too. It shows a separate thumbnailed view with all files attached to main Poser file. Then you may copy them, or do anything else as you wish.
Yarp - author of P3DO Organizer for Poser
