FuzzyShadows opened this issue on Mar 28, 2006 ยท 5 posts
FuzzyShadows posted Tue, 28 March 2006 at 8:32 PM
My camera came with butterfly lens hood, and I've seen pictures of the cone shaped hoods. What's the difference between the two shapes? Also, how often does everyone use their lens hood? Is it just for when the sun is out and in front of the camera? Thanks for any tips.
DJB posted Tue, 28 March 2006 at 9:24 PM
I use mine all the time.It protects the lens, and keeps out unwanted light sources. If you have a built in flash and need to use that, Take it off or it will cast a shadow. I also am guessing, but think the butterfly shape allows just enough light in without any vignette a solid one may cause.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
LostPatrol posted Wed, 29 March 2006 at 1:36 AM
Attached Link: Lens hoods DIY
Doug is right, the butterfly hoods help prevent vignetting (darkening of the edges of the frame) Most hoods for wide-short telephoto lenses are of the butterfly type, as these offer the best performance in that range, longer lenses usually have a solid hood without fins, as the narrow angle of view doesnt cause the issues with light drop off at the edges that that can be associated with wide lenses. I use a hood always, unless it is not possible because of obstacles. Richard posted a link for DIY lens hoods, which may help if you have lenses without hoods.FuzzyShadows posted Wed, 29 March 2006 at 10:33 AM
And here I wasn't even using mine at all. Thanks for the tips everyone.
TobinLam posted Thu, 30 March 2006 at 12:31 AM
If your hood causes vignetting you should throw it away and get a hood designed specifically for your lens. There is no excuse for it to get in the field of view. My zoom lenses have hoods that correspond to their wide settings so they don't cause vignetting.
