Subject: Lighting issue
Nosiferret opened this issue on Apr 02, 2006 ยท 3 posts
Nosiferret posted Sun, 02 April 2006 at 1:52 PM
I've got a little issue going on. Don't suppose anyone else has had the same. I've created a figure in Poser5 and I used the lights that came with the skin texture package. Normally, if I don't like the lights I will use a Python script that will complete reset all the lights so I can rebuild the lights again. I've not had any problems in the hundreds of times I've used this Phython script. But on this set of lights, they don't all erase, there are at least 3 or 4 of them left and then Poser locks up. I can't do anything with the lights like manually delete them. My cursor won't even register the light control panel. Nor can I go to the menu and reset lights. I've selected "saved" and opened a new Poser window and reloaded the saved file I had been working with and it shows up without lights. Today, I try it and apparently it had deleted my figure instead of the lights. I've got 3 "figures" showing up on the pull down menu but each one is showing a no actor. I've tried to manually delete the lights and it just will partially delete the actuall image on the light control section. I'm getting spotlight-32 etc, showing up and I can't delete them either by the phython script or manually. It's like they're a bug, is that possible? Buggy lights? I tried opening up in Poser6 to see maybe it was just a Poser5 issue but the same thing happens. It is like there is something Odd about the lights that came with the texture package. I've never had this happen before and now apparently my figure is gone so I'm going to have to rebuild it now.
