Moonbow opened this issue on Apr 03, 2006 ยท 7 posts
Moonbow posted Mon, 03 April 2006 at 10:18 PM
Hello everyone, I was wondering if anyone could tell me how I would go about taking a fin off the daz angelfish please? I need a small fin for another character, and someone suggested using a fin from the angelfish. I just can't figure out how to do that. Any help would be very appreciated. Thank you Moonbow
ockham posted Mon, 03 April 2006 at 10:35 PM
The key is the grouping tool. If the fin
is a body part, select it first. Assuming Poser 6:
Open the grouping tool. Hit 'New Group'. Give
it a name. Hit 'Select all', or use your
mouse to select the parts you want.
Look from various angles to be sure you've reddened
all the facets on all sides of the part.
When you've selected what you want, hit 'Create Prop'.
Close the group tool.
Nothing obvious will happen, but if you've done
the steps right, you'll have a new prop named
after the group name you filled in. You should
be able to grab it with the mouse and pull it
away from the main fish.
Delete the main fish figure, and save the prop
as a PP2.
Message edited on: 04/03/2006 22:36
Moonbow posted Tue, 04 April 2006 at 5:57 AM
Thank you for replying so fast Ockham:) I am using poser4. Could you tell me where to locate the grouping tool in poser4 please? I looked just about everywhere and can't seem to find it. I appreciate your help:) Moonbow
TrekkieGrrrl posted Tue, 04 April 2006 at 9:27 AM
:o) The actual placing may vary depending on how you've set up your screen :o)
ockham posted Tue, 04 April 2006 at 11:01 AM
It should work the same way in 4, except that the grouping panel is differently arranged. The important step is the 'Create New Prop' button, not 'Create Prop' as I listed (for P6).
Moonbow posted Tue, 04 April 2006 at 1:18 PM
Thank you for the image ernyoka1 :-) I picture is worth a thousand words LOL! Thank you too ockham, for telling me how to do it:) I will go try it! Hugs to you both ;) Moonbow
Moonbow posted Tue, 04 April 2006 at 10:15 PM
Wow :) I did it! It worked wonderfully. Thank you for all your help;) Moonbow
