dpoosch opened this issue on Apr 05, 2006 ยท 6 posts
dpoosch posted Wed, 05 April 2006 at 9:57 AM
I am trying to load Beyond Bents Bamboo model into P4 scene and I immediately get an out of memory notice. This was from the free stuff. I checked the archive and there are hundreds of entries on the subject but nothing seems to explain this. I have had this on several other models (usually from the free stuff). There are three files in the zip: Geometries, Charachter, and Texture. There is an object in the geometries folder which I loaded to the Beyond Bent folder. The other stuff was loaded into each file. Can anyone explain this?
kathym posted Wed, 05 April 2006 at 11:00 AM
Some models have memory requirements - off hand as an example, I'll use Sanctum's Grim suit which needs a required 500 megs of memory. Perhaps they too have a requirement that your system doesn't meet. I get memory error messages all the time .. and thats because i'm trying to do too much without enough resources.
Just enjoying the Vue.
:0)
randym77 posted Wed, 05 April 2006 at 1:00 PM
"Out of memory" doesn't really mean Poser is out of memory in Poser 4. It's the message that Poser 4 displays whenever anything is wrong. Usually, it has nothing to do with memory. Usually, if you unzip a product to your Poser folder, all the files will land where they're supposed to be. (Check "use folder names" if you are using WinZip.) If you still have a problem, try running CorrectReference on it.
svdl posted Thu, 06 April 2006 at 1:35 PM
Running STOMP (short for Spanki's Three-D Object Manipulation Program, search for STOMP and Spanki in Google and you'll probably find it) on the .obj might help. Some modeling programs make a serious mess of the materials and grouping when exporting to .OBJ, STOMP can fix that. It doesn't reduce resolutions or mess up UV mapping or whatever. I ran STOMP on LisaB's trees. Before STOMP, Poser crashed when 2 or more trees were loaded. After STOMP, Poser could easily handle 5 trees and more. I don't know, but it just might help.
mdbruffy posted Thu, 06 April 2006 at 10:16 PM
I'm afraid the problem isn't confined to Poser 4. 5 and 6 will put you through it also. Ran into it several times while working on my Red Sonja projects and again on my train. I was told Poser had some serious rendering problems to be dealt with and I'm starting to beleive it- so much so, I'm considering buying Carrara 5 to render projects that Poser won't.
Jules53757 posted Fri, 07 April 2006 at 1:57 AM
Did you install the P4 update for more then 1 Gig of memory (RAM and Virtual together)?
Ulli
