Subject: speeding up p6 interface?
dkM21 opened this issue on Apr 07, 2006 ยท 5 posts
dkM21 posted Fri, 07 April 2006 at 2:36 AM
having upgraded to p6 in dec I find I am using it less and less because the interface is so slow. I have a 2,9 ghz comp with 1500mb ram, I dont think it should move at a snails pace with just v3 dial twisting. Is there any settings to tweak to speed it up? thanks in advance.
EnglishBob posted Fri, 07 April 2006 at 3:59 AM
I run a 1.2GHz AMD with 1GB RAM, and P6 isn't slow; as far as dial twisting goes, anyway. There are delays going into the material room, and when switching back to preview after rendering, but it was ever thus. It may be an issue with your video adaptor, since P6 will use that to render the preview. Try switching between OpenGL and SreeD modes to see if there's a difference; and, as always, make sure your drivers are up-to-date.
kuroyume0161 posted Fri, 07 April 2006 at 4:07 AM
Must agree with EnglishBob on the video card suggestions. For some reason, the SreeD mode in Poser 6 is much more stable and faster than OpenGL. Plus, yes, make certain that you have the latest video card drivers.
 -- Bjarne Stroustrup
Ghostofmacbeth posted Fri, 07 April 2006 at 9:47 AM
Dial twisting in P6 does seem to suck and I know a bunch of people have mentioned it since ti came out.
modus0 posted Fri, 07 April 2006 at 11:35 AM
There's a file, named ImageIO_Mac.mrw in Runtime: ImageIOPlugins that can be either renamed or deleted, which seems to speed up Poser when it isn't there. I don't remember all of the details, but I've renamed it ImageIO_Mactemp.mrw and noticed at least an decrease in startup time. And I always use Fast Tracking instead of Full Tracking, and Smooth Shaded over Texture Shaded as the latter options are slower.
