Subject: Victoria3 And BodyPaint :
pumecobann opened this issue on Apr 09, 2006 ยท 13 posts
pumecobann posted Sun, 09 April 2006 at 9:06 AM
Hi. First of all, I'm not sure whether this should be here or in the Cinema4D forum... Here it goes anyway: I'm having a go at creating a skin texture for Victoria3 using BodyPaint. I'm able to paint onto the model directly now, but what's irritating is that I can only draw onto one part at a time using the RayBrush. Because the lips and head are considered seperate material groups, I can't paint a line, say, accross her face and lips in 'one' stroke. Is there any way this is possible? I've looked into seam-guides, but they're irrelavant here because I am painting directly onto the model. Sooooooooo, how's it done - if at all possible? Len. (Any help - much appreciated)
The wait can be horrific, but the outcome can be worse - pumeco 2006
Neyjour posted Sun, 09 April 2006 at 10:49 AM
What you're describing should be possible. I'm hoping to get C4D soon and have been reading up on the Body Paint module as well. Go to the Maxon site and click Products > BodyPaint 3D R2.5. Then over on the right, click on Projection Painting under the Highlights Tour. If that's what you're trying to do, then maybe you could try doing a search for tutorials on Projection Painting. 😄
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
nruddock posted Sun, 09 April 2006 at 10:54 AM
Use UVmapper to remove all the original material zones, replacing them with just two (head and body). Then you should be able to work with just two seperate maps (no way round this as they use the same UV space).
wdupre posted Sun, 09 April 2006 at 3:27 PM
Projection painting is definately the way to go. No need simplify the mats, as Projection painting can automatically paint across materials as long as all of them are selected.
spedler posted Sun, 09 April 2006 at 3:33 PM
Yes, and projection painting is there in v2, IIRC - no need to get v2.5 just for that. (Though there are probably other good reasons to do so!)
Steve
wdupre posted Sun, 09 April 2006 at 3:54 PM
Quote - "Yes, and projection painting is there in v2, IIRC - no need to get v2.5 just for that. (Though there are probably other good reasons to do so!)"
Yep, pretty sure it was in version 1 as well, from what I recall. actually 2.5 is not much of a jump from version 2, there are a few new features, such and normal map baking and things like that but not a lot that make it particularly better for poser map production.
pumecobann posted Sun, 09 April 2006 at 5:14 PM
Aaaaaaaaah, damn! Yeah, that Projection-Painting sure looks like what I'm after. I say damn because I'm using R1 - and it doesn't have that feature. Indeed, the problem is because of shared UV space - so I can see now, how selecting multiple textures and then using Projection-Painting would work. Aaarrrggghhh!!! Thanks all, much appreciated. Len. (Who's just discovered how much his upgrade is gonna cost) :scared:
SAMS3D posted Mon, 10 April 2006 at 3:50 AM
Honeslty for me, before I upgrade to BodyPaint, I would jump over to Deep Paint first, but that is me. Sharen
pumecobann posted Mon, 10 April 2006 at 7:35 AM
Would it solve my problem of drawing accross multiple parts in one stroke? If so, I'd certainly take a look at it 😄 I haven't looked at it in years, so I suppose it's evolved a lot now. What in particular makes you recommend DeepPaint, Sharen? Len.
DCArt posted Mon, 10 April 2006 at 2:38 PM
Honeslty for me, before I upgrade to BodyPaint, I would jump over to Deep Paint first, but that is me. I've just switched from Deep Paint and Deep UV to Body Paint, because Right Hemisphere has all but dropped their support of their products. :sad:
pumecobann posted Mon, 10 April 2006 at 3:08 PM
Hmmm... Yeah, I've just looked at their website and it seems kinda cold - very little info. It seems DeepPaint can paint accross multiple objects, but so can BodyPaint2.5. It looks like I'll be sticking to BodyPaint. Not only that, I've got Cinema4D8.5 with some modules - so it makes sense to stick with BodyPaint because of the intergration with it. Thanks all, at least now I know what to go for. 😉 Len.
SAMS3D posted Mon, 10 April 2006 at 3:55 PM
Well you are right, it was not like that before...too bad..but you are right, looks as if they have dropped the support. Sharen
DCArt posted Mon, 10 April 2006 at 3:59 PM
Yup, it is a real shame too. 8-(
