Subject: Textures, I think thats what they're called?
rworrilow opened this issue on Apr 10, 2006 ยท 2 posts
rworrilow posted Mon, 10 April 2006 at 9:39 AM
I'm sure this question has been asked many times.. and I want to apalogies for asking again.. But after looking through my uncles (Passed away) I noticed several photos of what looks like someones skin has been stripped from their body.. is there a tutorial on here that will show me how to add this skin to a current pose I have in Poser (Poser 6) And about Poses.. My uncle has/had 100's of poses also.. where would I look for them? Thanks In Advance!! Raymond
Acadia posted Mon, 10 April 2006 at 9:56 AM
Sorry to hear about your Uncle :( I take it that you are not familiar with Poser and don't know anything about it? If that is the case, here is what I usually tell brand new users. Sorry if it's long, but I remember how frustrated I was when I first got Poser and only got bits and pieces of information. A picture to show you the file structure of a Poser Runtime can be found here: http://www.daz3d.com/support/faq/index.php?id=94 Basically, what it boils down to in a nutshell: If you are looking for a Character or a piece of clothing/shoes, in Poser you will find them in ibraries/character If you are looking for hair, you will find them in either library/character/hair OR library/hair If you are looking for character texture addons, hair textures, clothing textures, you will find them in library/poses. Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2 If you are looking for props, they are located in library/props. Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop. Figure items are "conformed" or "parented" Props are parented. If you are just starting, it's best to get started on the right foot. DO NOT just install files into the runtime! That will only lead to frustration because you won't be able to find anything, and not all files are packaged equally and land up all over the place. Here is a link to a tutorial on using multiple runtimes. http://forum.daz3d.com/viewtopic.php?t=9060&start=0 *********************************************************** Once you get your files installed, the next thing you want to do is to start making things :) Here are some great newbie tutorials that will get you through the bare basics: http://trekkiegrrrl.dk/tut1.htm http://www.poserguide.nimprodaction.com/issues/issue2/cover.htm http://www.poserguide.nimprodaction.com/issues/issue3/cover.htm http://www.poserguide.nimprodaction.com/ http://www.canary3d.com/tutorial/3d-intro.htm http://www.ebonshire.net/tut-posb/index.php http://www.cooltuna.com/poser/poser-tutorials.html http://www.renderosity.com/tut.ez?Form.ViewPages=155&Form.sess_id=52280005&Form.sess_key=1129030101 *********************************************************** Clothing and textures are all figure/item specific, which means: Michael 3.0 needs clothing and textures made for Michael 3.0 Victoria 3.0 needs and clothing and textures made for Victoria 3.0 Victoria 2.0 needs and clothing and textures made for Victoria 2.0 Aiko needs clothing and textures made for her. Like figures, a texture made for one hair style can only be used on that hair style. Clothing is also specific when it comes to textures. A texture for a pair of pants, won't fit all pants... just the pants that it was made to fit. Same with all clothing items. Hair can be used across figure. You need to turn the Scale and XYZ Scale dials to get it to fit. If it's not for the figure it was made for, you will have to "parent" the hair to the figure. Poses can also be used across figure. If the pose is for a different figure, you will sometimes have to tweak a joint, or the fingers. So don't dispair if you only have faery poses for V3, but want to make a faery using Millennium Baby. As for those images you describe, they are in a folder called "textures"? Don't move those around. Leave them there. Also, don't move the files in the "Geometry" folder either. In fact, once you have files installed, there is no need to access your folders unless you want to uninstall or install something. In order to apply those skin textures to your figure in Poser, you do it inside Poser through the "Library/Pose" area. They are called "MAT Pose Files". To do that you open Poser, open the "Library" on the right, Click "Figures" and find the figure you want to use...probably Victoria 3 SAE, Click the icon, click the DOUBLE checkmark to add the figure to the Preview window. Go back to the Library, find the Pose folder, find your skin texture in there (hopefully it's organized and easy to find), Click the icon, and click the "SINGLE" checkmark to apply the texture to the figure. Make sure the figure is the active item in the window and not the camera.
