albertdelfosse opened this issue on Apr 10, 2006 ยท 2 posts
albertdelfosse posted Mon, 10 April 2006 at 11:30 AM
Got a question on collisions between 2 props in poser sr2. Sometime it works, sometimes it does not. I have selected detect collision in the properties menu for both a table and a floor prop, plus I set collision on in the collision menu. Now when I lower the table to the floor it goes right thru. If I load 2 box props into poser and do the same thing above it works. The 1 box will not go thru the second one. If I set in the collision menu the intersection option ie the polygons of a object turn red when 2 objects intersect.... well that works with the table, and the floor prop. I'm stumped as why it's not working with the floor prop. I'm wonder if it's cause it's a plane ie 1 sided square.
albertdelfosse posted Mon, 10 April 2006 at 11:53 AM
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2432948
I think I found a answer to my question ie this thread.
