Forum: Vue
Subject: a more convinsing waterfall?
odeathoflife opened this issue on Apr 10, 2006 · 9 posts
odeathoflife posted Mon, 10 April 2006 at 1:13 PM
Just gor Easel, and like it very much, but any tips on a more convising waterfall? There are two water layers there in the waterfall, and a couple cylinders with a cloud map on them for a spray but it isn't looking spectacular like I wanted :)
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
garyandcatherine posted Mon, 10 April 2006 at 2:03 PM
From my experience, the best and only conviencing way to achieve waterfalls is to paint them in in the postwork phase of your art creation. Go to the marketplace and look for photoshop brushes. There you will find waterfall brushes that you can paint onto your image. It requires just a little effort but the effects are absolutely wonderful. Good luck.
randym77 posted Fri, 14 April 2006 at 10:48 AM
Check out Forester's store, and her waterfall objects at ExpandingWave.com.  She does great water objects.
lingrif posted Fri, 14 April 2006 at 3:50 PM
They are also available from Cornucopia3D.
Lin
www.lingriffin.com
iloco posted Fri, 14 April 2006 at 4:23 PM
Look in the tutorial section  here at renderosity and look for lilzeek tutorial for waterfalls in vue.
  He uses alpha planes and they make a nice waterfall.
At one time these alpha planes were for sale.   Contact him if you like what you see in the tutorials.
ïÏøçö
LordWexford posted Sat, 15 April 2006 at 2:17 AM
I agree with garyandcatherine here, I've never yet seen a convincing waterfall effect done in Vue itself.
Check out Raptura's brushes in the marketplace here - at $5 for 30 brushes they are very good value for money.
GSGALAXY posted Sat, 15 April 2006 at 6:46 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1137804&Start=1&Artist=GSGALAXY&ByArtist=Yes
I think your Vue Easel waterfall is for sure one of the good looking ones ... good job ...
Just a little while ago i've tried to set up a waterfall scene (cascade style) myself, completely done in Vue 5 - no postwork - no alpha planes - result see the attached picture - really hard to get close to a real looking waterfall ...
I've just started with Vue 5 in Oct 2005 ... i guess, i have to try the alpha plane idea, too ...
forester posted Sat, 15 April 2006 at 10:31 PM
Your waterfall really looks pretty good, odeathoflife. For waterfalls, I'd recommend two things to you. First, try the Troubled Water material, if you weren't already doing so. Second, I don't have a copy of Easel, but in its Material Editor, can you adjust the angle of incidence of the reflected light. I get some reasonable results when I make the angle of incidence very low. This tends to make the white part of the reflection occur earlier, and it looks more like white foam that way. I wonder if I can create a "foam" bitmap that we call could use for this. Walks out of room for a little bit.....
odeathoflife posted Sat, 15 April 2006 at 10:34 PM
Thanks for all the tips and comments.
gary and catherine - I don't do post work :) well not ever but very rarly, I can't paint on a computer no matter how hard I try, it always looks muddy.
I will check out the incidence though sounds promising.
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
