Stan57 opened this issue on Apr 14, 2006 · 4 posts
Stan57 posted Fri, 14 April 2006 at 11:26 AM
The link is to an image i tryed to render and also the setting i used. What did i do wrong??
Thanks in advance
Stan
Jack Of All Trades Master Of None
markschum posted Fri, 14 April 2006 at 2:19 PM
If you are using the standard poser lighting of three lights you might check the freestuff for light sets.
you can add low intensity fill lights to lighten up the darker areas.
otherwise it looks good.
Miss Nancy posted Fri, 14 April 2006 at 2:33 PM
drop pixel samples to 2 or 3, to avoid the blur fx.
Stan57 posted Thu, 29 June 2006 at 7:44 PM
Thank you both, i will give it a try, right now i am working on installing a new drive and installing and replacing all my files and programs so it will be a few days llol
Stan
