Subject: Transmaps
cHEESE_GOW opened this issue on Apr 02, 2001 ยท 6 posts
cHEESE_GOW posted Mon, 02 April 2001 at 8:08 PM
I have to do some transmapping from what I understand, and I have no idea how to. Any help would be much appreciated.
bebop posted Mon, 02 April 2001 at 9:48 PM
What do you want to do a trans map of?
shadowcat posted Mon, 02 April 2001 at 11:34 PM
A transmap is the same as a texture map with the exception that what is colored white you will see, and what is black you will not. (gray will turn out halfway see through I believe)
hauksdottir posted Tue, 03 April 2001 at 1:44 AM
And the important thing is to not only create and load the transparency maps, but to adjust the slider bars for the relevant pieces of your figure or object.
cHEESE_GOW posted Tue, 03 April 2001 at 7:30 AM
So how would I map something like hair, or pants if I don't have a texture map for it?
shadowcat posted Tue, 03 April 2001 at 12:36 PM
you can make a tex map (and transmaps too) using any paint program. if you need a template get uv mapper (steve cox has one in free stuff, go flipping through the utilities section)
