ScottA opened this issue on Apr 19, 2006 · 6 posts
ScottA posted Wed, 19 April 2006 at 11:54 AM
Hi gang,
I'm playing around with Carrara5.
I'm trying to use Carrara as the middle man app. and import Poser animations, then save them as .FBX to use them in other programs.
But when I save as .FBX in Carrara. The animation gets stripped out and all I get is the default pose and skeleton.
Is there a special way to save .FBX files with the animations in tact?
danamo posted Wed, 19 April 2006 at 5:44 PM
Hope you don't mind me asking, but it helps the process of identifying the problem and helping to answer your question. You are using Carrara5Pro aren't you? I ask this because the "standard" ver. of Carrara5 won't import or export .FBX files.
ScottA posted Wed, 19 April 2006 at 7:22 PM
No problem dan.
Yes. It's the Pro version.
The key frames are there in Carrara before I save to .FBX. But the animation keyframes are gone when I open the .FBX file.
All it saves is the figure in the default pose, and it's bones.
ren_mem posted Wed, 19 April 2006 at 11:49 PM
This was discussed early on. Something about it not supporting animation. I don't know whether that is true or not. I would send this to eovia to get a definitive on whether it supports fbx animation. Which would really make sense, of course.
No need to think outside the box....
Just make it
invisible.
ScottA posted Thu, 20 April 2006 at 9:15 AM
Wow. That's really bad news.
Thanks for the replies.
Ringo posted Thu, 20 April 2006 at 10:32 AM
That is correct it doesn't support FBX export of animations.
Ringo
