Forum: DAZ|Studio
Subject: Daz Lighting help sought..
Dynamo opened this issue on Apr 20, 2006 · 6 posts
Dynamo posted Thu, 20 April 2006 at 1:49 PM
Daz is easy to use of course on most levels, however as a longtime poser user I just cant get a handle on lights, my renders come out really far darker than I find acceptible.  Is there somewhere a tutorial, or some settings to help me get started?
Thanks in advance.
  Dyna
jroulin posted Fri, 21 April 2006 at 7:58 AM
Hi there is a simple thing you can do to help to improve quickly. When you load a spot or distant light you can change the camera view and look throw your light. This allows you to use the same displacements icons in the “view” window as you use for the camera. So you can see where you are pointing the lights. You then have simply to adjust the lights strengths and colures.
Dynamo posted Fri, 21 April 2006 at 9:14 AM
Hello,
  Thanks for the reply I shall give that a try certanly!
lior posted Sat, 22 April 2006 at 7:37 PM
Hi,
At
http://www.daz3d.com/support/tutorial/tutorial.php?id=1618&trid=669317171
you have a tutorial speaking about the lights with dazstutio.
Have a good luck :biggrin:
Dynamo posted Sun, 23 April 2006 at 9:52 PM
Thanks as well for the link I appreciate the help.
maclean posted Tue, 25 April 2006 at 7:57 PM
I have a tutorial on cameras and lights in daz studio which you should find helpful.
http://digilander.libero.it/maclean/DStutorial.htm
It was written 2 months ago, so it's still up to date.
mac
