Gurichi opened this issue on Apr 20, 2006 ยท 2 posts
Gurichi posted Thu, 20 April 2006 at 3:17 PM
As the title says, I'd like to know how to make a second skin belt that I could apply to Aiko. I'd also like to know if it's be possible to put a bump map on the belt map thing to make it look like its popping out like a real belt would.
SamTherapy posted Thu, 20 April 2006 at 3:58 PM
Yep, dead easy.
Open the texture you want to apply the belt to in Photoshop or PSP, depending on your weapon of choice.
Make a new layer.
Paint the belt.
The next bit assumes you're using P5/P6
Discard the skin texture and flatten the belt.
Save the belt.
Make a bump map.
Save that.
Then, using the "masking" technique in the Material Room, you can apply the belt and bump to any texture you choose.
