Methastopholis opened this issue on Apr 20, 2006 · 4 posts
Methastopholis posted Thu, 20 April 2006 at 4:23 PM
ok i give up what the right setting for rendering out your aniamtions in Flash .
this is one of my results with james : 30 frames one . one of these link will take you to a flash that i made and you can see my issues if Neeeded.
[url=http://media.putfile.com/testguy]Click here to watch testguy[/url]
Video](http://www.bofunk.com) and Code Provided by BoFunk.com |
xantor posted Fri, 21 April 2006 at 1:13 PM
If you have a program that can make flash files, you would probably be better doing a standard render and using that to convert to flash.
ockham posted Fri, 21 April 2006 at 1:50 PM
Ditto. Poser's direct 'render to flash' is entirely too slow and
strange. When it fails, you'll have to restart over and over.
Best to render to separate frames, and use something like
MotionSWF (or a proper Flash Editor if you have one) to
assemble the images into an SWF file.
MotionSWF free download:
http://www.vector.co.jp/soft/win95/art/se226046.html
MotionSWF doesn't come with usable instructions, but
it's quite simple to use.
Put the images in a folder of their own, along with the
sound (if any) in MP3 form.
Open MotionSWF.
Open Windows Explorer and browse to a view where
you can see the image folder.
Drag the image folder (as a folder) into the middle of MotionSWF,
and hit File:Convert. Pick compression and FPS.
Methastopholis posted Fri, 21 April 2006 at 6:20 PM
thanks guys you beena big help
