vanwin opened this issue on Apr 22, 2006 · 14 posts
vanwin posted Sat, 22 April 2006 at 9:21 PM
Is it possible to turn a prop into a light source?
Thought I saw a tutorial or something mentioned in the forum, but now I can't seem
to find it ....
SamTherapy posted Sat, 22 April 2006 at 9:45 PM
I believe it's possible with the Probe Light node but I can't remember in any detail how it works.
However, if you're using P6, you can put a Point Light inside a sphere.
dphoadley posted Sat, 22 April 2006 at 11:51 PM
stonemason posted Sun, 23 April 2006 at 12:11 AM
dphoadley posted Sun, 23 April 2006 at 2:12 AM
SamTherapy posted Sun, 23 April 2006 at 7:59 AM
Quote - Yes, but what about Poser Pro?
David
Not possible but you can fake it. Search for Globall in Freestuff.
dphoadley posted Sun, 23 April 2006 at 9:48 AM
vanwin posted Sun, 23 April 2006 at 10:37 PM
I'm still learning how to use P6, so forgive my ignorance but how do you put a point light into a
Sphere? : )
pleonastic posted Sun, 23 April 2006 at 10:44 PM
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2657573
vanwin, check the attached thread.swfreeman posted Mon, 24 April 2006 at 8:54 AM
ive never got the gather node bioilum effect to work... even used the exact same settings..raytracing on...blabla.. the prop i apply the material to (cube primitive) stays black in renders
bagginsbill posted Tue, 25 April 2006 at 9:11 AM
Here is a poser primitive "cane". The ambient color of the cane is green. Behind it is a one sided square with the material as shown. All my lights are completely off, so the only light on the one sided square is coming from the gather node. You can clearly see the glow. But its ugly.
Nance posted Tue, 25 April 2006 at 7:07 PM
Attached Link: Glows Post - P4
FlyByNight posted Tue, 25 April 2006 at 7:45 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=692097&Start=150&Artist=FlyByNight&ByArtist=Yes
I've used SnowSultan's Globall lighting quite a few times and think it works very well if you have the patience to adjust all the lights to achieve the effect you are looking for. The link is to one of my images where the effect came out as perfectly as I had imagined it to look. Yes, it took some time to get it just so but well worth the effort. Most of the time working on an image, for me, is getting the lighting right, then second would be the posing. One can spend hours and hours working on both.FlyByNight
vanwin posted Thu, 27 April 2006 at 12:03 AM
