Forum: Bryce
Subject: How to create a destroyed city?
Robert_Ripley opened this issue on Apr 27, 2006 · 8 posts
Robert_Ripley posted Thu, 27 April 2006 at 6:40 AM
Has anyone a destroyed city like Dystopia after bombing or nuclear strike or else?
I need it as a part for my next Wallpaper.
draculaz posted Thu, 27 April 2006 at 9:18 AM
it's pretty complicated... what i would suggest is if you have distopia to spread out hte buildings and just create the destroyed ones in between. with a bit of smoke and changed textures it could work.
m
Robert_Ripley posted Thu, 27 April 2006 at 9:39 AM
no it should look like some ruins of the city
i tried to add some stones on the city and make them negative, group them with the buildings so it should look like the stones were the ripped off pieces
i can add some pictures if you need ;)
Nicko15 posted Thu, 27 April 2006 at 9:43 AM
Attached Link: ruined city
I did it by using bryce rocks and negative boolean operations to cut out big chunks from buildings.  Then I put in thin meshes to show the reinforcements.  Good luck with the city!
sackrat posted Thu, 27 April 2006 at 12:23 PM
You could always render the Dystopia city in Bryce from a top view,.........then in an image editor(such as Photoshop or Paint Shop Pro)convert that image to greyscale, then create a lattice terrain object using that greyscale image as your heightmap, then create the destructions with a brush in the terrain editor. Just a thought.
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
danamo posted Thu, 27 April 2006 at 1:00 PM
Sackrat has a good workable idea, but I would do an altitude render from top view instead of a regular render because the altitude render is already greyscale.
pakled posted Thu, 27 April 2006 at 10:23 PM
If you can find the UKKO3d 'USS Derelict' mat, that would probably work well. Ed Baumgarten has several ruined buildings for close-up work (Baument.com, if'n I remember correctly)
rj001 posted Fri, 28 April 2006 at 8:16 AM
Attached Link: http://www.avalon3d.com/citytut.htm
this link from my website may help
Experience is no substitute for blind faith.
http://avalon2000.livejournal.com/ - My Art Blog
http://jeferies.jalbum.net/Richard%20Jeferies%20Future%20Perfect/
