Bez opened this issue on Apr 27, 2006 · 9 posts
Bez posted Thu, 27 April 2006 at 12:52 PM
The tablet part of my Wacom Intuous 3 has got scratched and worn in 2 places, due to continuous use, any ideas what I can do as I really can't afford to buy a new one right now.
dreamer101 posted Thu, 27 April 2006 at 2:00 PM
Attached Link: WacomDirect Accessories
You can get a replacement transparent overlay.
Bez posted Thu, 27 April 2006 at 4:19 PM
Thanks for the info. I checked it out but it appears they are out of stock, I'll check again later, thanks again Dreamer, much appreciated
dreamer101 posted Thu, 27 April 2006 at 6:13 PM
Your welcome. I'm sure if you shop around at wacom dealers you could find it. I did notice the 6 x 8 was out of stock and of course that is probably the one you needed. That must be the most used size.
Bez posted Fri, 28 April 2006 at 4:41 PM
I just found out that a clear thin sheet of plastic film taped over the top of the pad works a treat, and a lot cheaper too. It now works a treat :)
Bez
Quest posted Fri, 28 April 2006 at 10:12 PM
LOL...yes, that's all it is, a thin peice of plastic. In fact, only used when copying photos and images as tracings. I'm sure that would do until you can get your hands on a regular. Who know's, you might not want to anymore.
fetter posted Wed, 03 May 2006 at 4:01 PM
The question's moot now and I'm sure you've thought of it already, but could you have simply turned the old one over?
Bez posted Wed, 03 May 2006 at 4:15 PM
Hmm, turning it over? that's an idea.... thing is I've got a Wacom Intuous 3, the drawing pad is set inside the tablet and not loose, but if anybody knows if you can safely prize it out without damaging the whole thing, I'd be glad to hear about it.
bogwoppet posted Mon, 22 May 2006 at 2:08 AM
The plastic cover is only held in place by double-sided tape, I replaced my one a few weeks ago without any problem.
Hope this helps.
Tony
