Forum: 3D Modeling
Subject: maps in 3D
ccp opened this issue on Apr 28, 2006 ยท 4 posts
ccp posted Fri, 28 April 2006 at 5:23 PM
Hi to everybody. After posting my problem in the 2D forum, somebody was convinced all that is done with a 3D program. I would like to create a map of my area in this way even if I am a beginner. Can somebody help me which software they have done it ? Its a part of a screenshot of a pc game but shows the way I would like to do it too.
Thanks to all
ccp posted Fri, 28 April 2006 at 5:24 PM
and another shot
Mikewave posted Fri, 28 April 2006 at 6:03 PM
Well, for this you definitely need 3D software... I myself am a Lightwave-freak, so I know how to do it using LW, but any 3D program could get the job done... For lightwave I'd sugest either two aproaches; -either create a simple surface (a 4 point polygon), convert the first pic you've posted into a black and white pic (using photoshop or any other 2D program that can do so) and ad this pic as a bump map into surface editor. -Or, create a 4 point poly with enough segments, use the magnet tool to raise the points or polys you've selected and create your elevations, then use Smoothshift to ad the detail. There is a program called Terragen that is specifically used for creating landscapes, much like the one you need, so maybe try the gallery and see who you want to contact by Instant messaging... Good luck, Mike
Coming soon
ccp posted Fri, 28 April 2006 at 6:15 PM
Hi,
many thanks for your advices. Will try as you told with lightwave. Am curious what will be created...:-)
