Subject: My brief render settings experiment results:
unzipped opened this issue on Apr 29, 2006 · 45 posts
unzipped posted Sat, 29 April 2006 at 6:11 PM
O.k., so for a while I've been living with render times that seemed soooo long to me and I often wondered what I could do to speed things up - without losing much image quality.  So I've wasted my Saturday doing the tedious task of altering render settings one variable at a time, one increment/decrement at a time.  I'm here to share the fruits of my labor with you all, and more importantly get feedback from you all.  Sorry if this ground has been covered before (I'm sure it has), but what the heck.
So to put a few initial parameters out there:
Hardware/OS:
AMD 2.1 G processor
NVidia GeForce 4800 graphics card (Open GL enabled)
1.5 GB memory (pc2700)
MS Windows 2000
Poser 6 SP 2
In the test I used one infinite light and one IBL.  No shadows on the IBL, the shadow map size for the infinite light is set to 8192, shadow blur radius 2.5, minimum bias 0.10000,  (display units in inches).
The model I used in the test image was V3, shooting with the face camera, which always seems to take longer (probably because there's more detail in the face than anywhere else).
I'm using Face Off's Occlusion Master and Unimesh Realism Kit - so the character itself is bearing Ambient Occlusion nodes.  I'm using Robin, a texture by A_ (a beautiful texture in general, but even greater if you're needing a redhead - http://market.renderosity.com/mod/bcs/index.php?ViewProduct=31022), with a body texture map of size 3000x4000 (approx 1.8 MB), a head texture map of size  4000x2720 (approx 2.1 MB).
I normally have been using render settings I got from Face Off (I forget where/how exactly) which give great results.  So I started with it as a base and adjusted from there, trying to adjust various settings to improve performance.  The settings follow as images, with the resulting renders after that.....
unzipped posted Sat, 29 April 2006 at 6:14 PM
Face Off's render settings
unzipped posted Sat, 29 April 2006 at 6:15 PM
the render settings I ended up with as the best compromise of speed and quality
unzipped posted Sat, 29 April 2006 at 6:20 PM
a side by side comparison of the resulting renders
unzipped posted Sat, 29 April 2006 at 6:22 PM
here's a split screen image combining the two renders together
unzipped posted Sat, 29 April 2006 at 6:40 PM
O.k. so what changed?
from Face Off's settings to the compromise settings I moved:
number of raytrace bounces from 2 to 1
min shading rate from .50 to 1.0
number of pixel samples from 3 to 2
did not change the max texture size
max bucket size from 128 to 256
Comparing images it's hard to see much of a difference.  The one notable exception is in the area of the eyelashes - you'll notice the render at the compromise settings has eyelashes that are clumpier or less smooth, along with the shadows for the eyelashes.  There's also possibly a bit less smoothness in the shadow edges, and perhaps a bit less detail in the lips.
For that price, I cut my render time in half, from 10 minutes to 5 minutes.
Some lessons learned going off the base line, here are the effects of changing individual parameters:
Moving the number of pixel samples from 3 to 2 took 1 minute off the render time but it seemed the resulting image was a  bit less clear
Moving the number of pixel samples from 3 to 1 took 3 minutes off the render time but gave unacceptable aliased jagged results
Moving the number of raytrace bounces from 2 to 1 took 1 minute off the render time with no noticeable results - however there's not much reflection or refraction going on here (some in the eyes which I see no difference in), so I don't know if this is the best test of that setting.
Moving the min shading rate from 0.50 to 1.00 took 4 minutes off the render time, with barely noticeable results except for the eyelashes and shadows of the eyelashes being a bit less smooth
Moving the min shading rate from 0.50 to 5.00 took 6 minutes off the render time, with noticeable results as the overall image became a bit more grainy, but the results weren't remarkably bad - they could be passable for quick decent quality results.
Moving the texture size from 4096 to 2048 took 2 minutes off the render time, giving slightly less texture detail resulting in a loss of sharpness, but provided decent quality
Moving the texture size from  4096 to 1024 took 3 minutes off  the render time, without much difference from the 2048 render
Moving the texture size from 4096 to 512 took 3 minutes off the render time, with noticeable results, definite loss of detail, especially in the lips - not worth it when it clocks in at about the same time as the 1024 size
Moving the bucket size from 128 to 256 took 3 minutes off the render - no change in image quality
Moving the bucket size from 128 to 512 took 3 minutes off the render - no change in image quality
So it appears the largest factor in the quality/time trade off is the shading rate.  When I left all the settings from Face Off the same and only moved the shading rate up to 1.0 and the bucket size up to 256 it took 4 minutes off the render (6 minute render time).  As bucket size does not affect image quality, it seems to leave the shading rate as the thing which will most greatly determines your render time vs. render quality.
As mentioned many times before you'd want to get your bucket size up as large as your system can handle as long as you can live with poser being somewhat less responsive while you render.
I think with my compromise settings or a very slight variation thereof I've found a good render setting which will produce quality results in less time.  I don't know if this helps anyone but me, but I'd love to hear feedback or have people contribute more information on this - especially if you're not seeing what I'm seeing.
richardson posted Sat, 29 April 2006 at 7:32 PM
I think each point drop (1.00) on the shading rate means your pc has to calculate 100 micropixels. This is where the real damage is. Hair (and eyelashes) suffers the most here when shading rate is high. Poser's scale is about 1/100th the scale of most apps, too. Textures are usually too big for poser to read, hence lowering the shading rate to get more accurate reads.... and the vicious cycle begins. Or,,, Cut the huge hair textures in half along with the tR maps. Leave shading rate at 1.00 or higher. Get clear results. In half the time. Stewer trick. Another time gain is lowering the shadowmap. A map of 3072 I consider huge and reserved for "final only" renders. I've clocked 7 hours for a 3072 spot to render its shadowmap. A map of over 8000 I think, is way more than you need for these tests. Effects are nice, though. No question. face_off's lightsettings are designed to get RayTrace/like shadows in clarity and shadowmap/like quality in shadow blur and glow or leaked light reduction(ears, nostril, lacs, mouth). I remember his settings as; 3072map, 0.01bias, 10-12 blur along with a few tinted rimlights. The results are really good but, that bias setting is a killer...but neccessary. As far as bucket size, I let P6 decide when it needs to split. I'm always down to 32 before I know it. It really is effective to raise it if you have a "light" scene. On RayTrace bounces... Try to have RayTrace checked but have bounces on 0. This allows AO to function without a wait. Bounces are strickly Reflect/Refract (Imo) so unless you have reflect attached to eyewhites/corneas, you can save some time there, too. And don't forget the body...make invisible whatever is not in the viewer. Big savings in memory.
richardson posted Sat, 29 April 2006 at 7:36 PM
And thanks for the great post. I love this stuff and it kills me when I see some settings people keep crashing with.
byAnton posted Sat, 29 April 2006 at 8:40 PM
Cool. I notice that with procedurals, A higher MinShade rate causes the procedural to look larger the further away the camera gets.
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the face of truth is concealment."
Over 100,000 Downloads....
linkdink posted Sun, 30 April 2006 at 2:55 AM
Great post, thanks for all your experimenting and posting your results. Also thanks to richardson, as always, for his great tips.
Gallery
dphoadley posted Sun, 30 April 2006 at 5:16 AM
BM
  STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
unzipped posted Tue, 09 May 2006 at 1:55 PM
Since we last spoke I looked into some of Richardson's ideas.
Firstly I found that since I was using raytraced shadows, the shadow map setting had almost no affect on my renders at all, neither in terms of quality or time of render. I haven't done much with depth mapped shadows since I got Poser 6 - I don't know when I'll look into this.
I also found that the shadow blur radius didn't really affect time of render given the other settings I'm using.  It definitely changes the resulting render about as you'd expect - a low setting resulted in very tight shadows, a higher setting resulted in very fuzzy dispersed shadows.  I found with the settings I have here the higher radius produced unsatisfactory results - too grainy.  I believe I'd need to up the shade rate and the pixel samples to produce good quality dispersed (high radius) shadows - which would definitely increase render time.   The type of shadow you're going for will determine what you can do here - I generally like the sharper shadows myself, so I'm happy with the low radius settings.
I'm going to look into Richardson's comments about hair and transparency map size soon.  I'll report back here with results as I get them.
Unzipped
richardson posted Tue, 09 May 2006 at 2:32 PM
Unzipped, Yes, RayTrace "maps" are really a leftover from P4 or shadowmap lights and serve no purpose. I set them to 256 in case there is a quick memory calc that I can avoid. RayTrace shadows are severe and blur(5-12) does not take care of all of it so, I usually set shadow to 0.400 to help disperse it (on skin). If using a spot you can choke the angle 0start 60end to soften some more. You need an ibl fill in the scene for this... it takes up the slack on the mainlight. A rimlight can either assist the mainlight or (attached) create a nice highlight (RayT also). With this setup, I can crank out a render every 6-10 minutes with decent results. Granted, not as spectacular as a nice face_off setup but, 10 times quicker. Switching the mainlight to shadowmap/3072 for the final is a nice alternative. So, you were using RayTrace in your tests? That explains the eyelash shadows! Shadowmaps don't do eyelashes too well. Also, before you raise pixel samples or shading rate, try scaling your scene 1000%. I have yet to test this but I'm sure it's a solution for something. RayTrace is strangled at Poser scale. Reflect/Refract/artifacting dissappears at 1000% scale. Ronstuff proved this in P5 on an old thread of mine. Bump and some other shader nodes do not scale with the figure so, a manual job will be needed. 0.01bump becomes 0.100 at scaled version. Worth a look into... When you get to hair, please let me know.
unzipped posted Tue, 09 May 2006 at 5:47 PM
Quote - ...RayTrace shadows are severe and blur(5-12) does not take care of all of it so, I usually set shadow to 0.400 to help disperse it (on skin).
Just to be clear, when you say "set shadow to 0.400" you're talking about the shadow bias - or is it something else?  If it's bias I usually start with it at about  0.1 and then adjust it if I'm getting ambient occlusion related artifacts.  I usually don't go higher than 1.1 or lower than 0.01 (and very rarely at that), but I've not noticed any render time impact as a result.
Quote - If using a spot you can choke the angle 0start 60end to soften some more. You need an ibl fill in the scene for this... it takes up the slack on the mainlight. A rimlight can either assist the mainlight or (attached) create a nice highlight (RayT also). With this setup, I can crank out a render every 6-10 minutes with decent results. Granted, not as spectacular as a nice face_off setup but, 10 times quicker. Switching the mainlight to shadowmap/3072 for the final is a nice alternative.
I'd be really interested to see your "standard" render settings and light set up - any chance you could post them here?
I often find myself wishing there were additional raytrace settings on the lights so that for instance they did only specular and didn't add more actual light to the scene or so they only cast shadows and don't add any light to the scene.  Then you could use one ibl for the actual light, one for specular/reflection/refraction and either the same one or a different one for shadows.  Maybe there's a setting in there I haven't found or hacked that will allow for that - but I haven't found it yet.
Quote - So, you were using RayTrace in your tests? That explains the eyelash shadows! Shadowmaps don't do eyelashes too well.
Yeah, I've got my default environment set to load up with just two lights, one infinite and one ibl.  I only have shadows enabled for the infinite light - raytraced.  I mess around with the intensity of the two depending on what I'm after, but generally the infinite is the main light and the ibl is the fill (I forget which but one of FaceOffs scripts (realism or occlusion) doesn't work with IBL as the more prominent light in the scene).  I can do o.k. with those two - it's a workaday arrangement.  If I want to get more involved/spectacular I can add lights from there.
Quote - Also, before you raise pixel samples or shading rate, try scaling your scene 1000%. I have yet to test this but I'm sure it's a solution for something. RayTrace is strangled at Poser scale. Reflect/Refract/artifacting dissappears at 1000% scale. Ronstuff proved this in P5 on an old thread of mine. Bump and some other shader nodes do not scale with the figure so, a manual job will be needed. 0.01bump becomes 0.100 at scaled version. Worth a look into...
This is fascinating stuff.  It's amazing how the incredibly bad mistake of what the default Poser scale was set to in the beginning  has had such long lasting and numerous negative affects.  I'm somewhat loath to do the scaling thing since I'd have to adjust all the cameras, figures, props and everything too, but it might be interesting to see what scaling up can do.
Quote - When you get to hair, please let me know.
Will do - perhaps this weekend.
richardson posted Tue, 09 May 2006 at 6:38 PM
Just to be clear, when you say "set shadow to 0.400" you're talking about the shadow bias - or is it something else? If it's bias I usually start with it at about 0.1 and then adjust it if I'm getting ambient occlusion related artifacts.." Bias, you want high in RayTrace(like maps, does not seem to do much). @1.00. Lowering the actual shadow intensity is what I meant @0.400 "I often find myself wishing there were additional raytrace settings on the lights so that for instance they did only specular and didn't add more actual light to the scene or so they only cast shadows and don't add any light to the scene". You are in luck! Intensity dials down to negative values in P6 (-2.000). No light,,more shadows. "I'm somewhat loath to do the scaling thing since I'd have to adjust all the cameras, figures, props and everything too".. In luck again! Load a primitive box. In hierachy editor, drag all pertinant matter over the box including your cams and lights you'll use. Check your main cam and then scale box to 1000%. Nothing should change in the viewer. Flippin back to 100% box when you want to compare... Scaling up to 10,000 to 100,000 will solve iris/cornea artifacting, too. I can send you a pz3 with my lightset. It would be more effective. Speaking of IBL,, I've noticed that light base AO should be about 1/10th in settings as material based AO. I've dialed down AO in this lightset.
unzipped posted Tue, 09 May 2006 at 7:30 PM
Quote - Bias, you want high in RayTrace(like maps, does not seem to do much). @1.00. Lowering the actual shadow intensity is what I meant @0.400
Ahh, now I understand which setting you're talking about.  As for bias, as I said I only change it when I notice A/O related artifacts - otherwise it doesn't have much affect.
Quote -   You are in luck! Intensity dials down to negative values in P6 (-2.000). No light,,more shadows.
That's a great tip.  Does it work for both depth mapped and ray traced shadows?  I assume such a light would still not generate any specular though.
Quote - In luck again! Load a primitive box. In hierachy editor, drag all pertinant matter over the box including your cams and lights you'll use. Check your main cam and then scale box to 1000%. Nothing should change in the viewer. Flippin back to 100% box when you want to compare... Scaling up to 10,000 to 100,000 will solve iris/cornea artifacting, too.
Now that's good squishy - I can see why we pay you the big bucks.  I can't wait to try this out.
Quote - I can send you a pz3 with my lightset. It would be more effective.
That would be much appreciated!  Can an empty pz3 be small enough to send via email?  If so you could try sending it to my shulkophile@yahoo.com account.
Quote - Speaking of IBL,, I've noticed that light base AO should be about 1/10th in settings as material based AO. I've dialed down AO in this lightset.
I've noticed that too.  Since I've started using occlusion master, I don't really use light based A/O anymore though.  I suppose if I wanted to up the realism a bit more I should turn that on for my IBL, but I don't want to pay the render time price for the extra shadows usually.
Rance01 posted Wed, 10 May 2006 at 5:00 AM
Great thread.  Have to come back and read this again.  Bookmark.  Thanks unzipped.
Rªnce
richardson posted Wed, 10 May 2006 at 7:19 AM
Sorry unzipped, I've got a server problem suddenly. I may have to upload to a host. This means I'll have to really clean this up, too. May be some time,, r
semidieu posted Wed, 10 May 2006 at 7:54 AM
Very intersting thread. I'm looking forward for the hair comparison.
Also, will look if i have some time to do it too, because i made an application to reduce quickly the textures found in a scene. Once i finished my actual render, i will try it.
unzipped posted Wed, 10 May 2006 at 12:44 PM
Quote - Sorry unzipped, I've got a server problem suddenly. I may have to upload to a host. This means I'll have to really clean this up, too. May be some time,, r
No problem, take all the time you need - I hope your server problem isn't serious.
kobaltkween posted Thu, 11 May 2006 at 11:52 PM
will there be a sort of final render settings post?  because i think i've gotten lost on recommendations,  other than high bucket size is good.  oh, and unzipped, you know you can change the shading rate for each object/group, right?  so you can leave the render setting (minimum value) low, boost it up high for things where it doesn't matter and make it low for stuff where it does (like hair, eyelashes, etc.).    i mean, i'm betting you know since both you guys seem to be much more knowledgeable than i, but i thought i'd check.
unzipped posted Fri, 12 May 2006 at 10:43 PM
Quote - will there be a sort of final render settings post?  because i think i've gotten lost on recommendations,  other than high bucket size is good.  oh, and unzipped, you know you can change the shading rate for each object/group, right?  so you can leave the render setting (minimum value) low, boost it up high for things where it doesn't matter and make it low for stuff where it does (like hair, eyelashes, etc.).    i mean, i'm betting you know since both you guys seem to be much more knowledgeable than i, but i thought i'd check.
I'm trying to work up to "final" render settings -  but in truth I don't think there will end up being any such thing.  It seems I'm developing a few different settings depending on which compromises I'm willing to make - but I think I'm zeroing in on one that's a good balance of quality and speed.  If I manage to get such a setting together I'll definitely post it here.
The individual object shading rate is something I knew, but it's something I always forget about - so it's definitely worth mentioning whenever anyone feels like mentioning it, so thanks very much for bringing it up.
I'm starting to do hair rendering comparisons now, I'm on my first baseline render using face-off's settings one V3 and Wild Hair - nothing else in the scene - shot from the face camera.  It's ugly time wise - it's been about 47 minutes and I think it's about half way done.  I've got to believe there's plenty that can be done to improve on that, but we'll see...
Unzipped
richardson posted Sat, 13 May 2006 at 5:35 AM
Hey, unzipped, What are your Light settings? Are you going RayTrace or shadowmap? Spot or infinite,,,? Rim lights? I may be able to duplicate this as I have "Wild hair" and am unable to upload a zip until I get something fixed. >>>"I'm starting to do hair rendering comparisons now, I'm on my first baseline render using face-off's settings one V3 and Wild Hair - nothing else in the scene - shot from the face camera. It's ugly time wise - it's been about 47 minutes and I think it's about half way done. I've got to believe there's plenty that can be done to improve on that, but we'll see..." That lightset was never meant to be fuel efficient. Are you sure you want to test with these settings? You kinda picked a "Rolls Royce" for a sprintcar challenge....It deals with light leaks(0.01bias) very well and deliveres a crisp shadow (3072map). These are the 2 speed culprits. face_off has explained this here publicly. If you have your primary light as RayTrace, then it's not a face_off lightsetting. The more I know, the better. Just checked out Wildhair....a dozen separate imagemaps to switch out later,,, groan. lol
unzipped posted Sat, 13 May 2006 at 10:57 AM
Quote - Hey, unzipped, What are your Light settings? Are you going RayTrace or shadowmap? Spot or infinite,,,? Rim lights? I may be able to duplicate this as I have "Wild hair" and am unable to upload a zip until I get something fixed. >>>"I'm starting to do hair rendering comparisons now, I'm on my first baseline render using face-off's settings one V3 and Wild Hair - nothing else in the scene - shot from the face camera. It's ugly time wise - it's been about 47 minutes and I think it's about half way done. I've got to believe there's plenty that can be done to improve on that, but we'll see..." That lightset was never meant to be fuel efficient. Are you sure you want to test with these settings? You kinda picked a "Rolls Royce" for a sprintcar challenge....It deals with light leaks(0.01bias) very well and deliveres a crisp shadow (3072map). These are the 2 speed culprits. face_off has explained this here publicly. If you have your primary light as RayTrace, then it's not a face_off lightsetting. The more I know, the better. Just checked out Wildhair....a dozen separate imagemaps to switch out later,,, groan. lol
No I'm just using his render settings - I don't have his light settings.  I started with his settings as my high quality baseline to compare against - you've got to have a control in any experiment and his render settings are a known quantity.  My lighting setup is the same as it was before (top of post), I'm trying to keep as many things as constant as possible during these tests.  So we're using raytraced shadows, not mapped.  I picked the Wild Hair because I knew intuitively that it was a beast in terms of render times, and I'm also going to compare it against a more lightweight hair model.
Results soon to follow....
unzipped posted Sat, 13 May 2006 at 5:21 PM
Allright I'm about done with this for now.  Specs haven't changed from what I've mentioned at the top of this thread (light setup, face_off's shader settings, hardware, etc.).  The only thing to note is what I'm calling my compromise render settings which are my attempt to get a good combination of timely renders and good quality images - you'll have to judge the results for yourselves.  I compared render settings against two different hair models - the Wild Hair (available here in the marketplace - a very realistic hair/materials package) and the Long Hair Evolution (Kozaburo's - gold standard hair).
Let's get to the facts...
unzipped posted Sat, 13 May 2006 at 5:23 PM
Here are my compromise render settings.  Let me say here that I think these are what I'm going to be working with most of the time from now on in my rendering - I'm happy with the quality vs. time results for rendering with the face camera.
unzipped posted Sat, 13 May 2006 at 5:26 PM
Here are the settings for my main light.
unzipped posted Sat, 13 May 2006 at 5:28 PM
Here are my secondary/fill light settings.  These are the only two lights in the scenes.
unzipped posted Sat, 13 May 2006 at 5:35 PM
Here's a comparison of rendering the Wild Hair at the different render settings.  Notice a bit more graininess in the highlights of the hair in the picture rendered with the reduced render settings.  You can probably detect a few more flaws in the reduced render settings image, but objectively the difference between the two doesn't seem that great to me.
unzipped posted Sat, 13 May 2006 at 5:39 PM
Just for comparison here's a render which involves texture reduction - I reduced all the maps for the hair to approximately 1/4 their size, and I set the max texture size in the render settings to 1024.  Note the very obvious loss of detail.  This render took aprroximately the same amount of time (give or take a minute) as the compromise render settings image without texture reduction.
unzipped posted Sat, 13 May 2006 at 5:47 PM
Here's the Koz Long Evolution comparison.  Again, notice a bit more graininess in the highlights of the hair in the picture rendered with the reduced render settings.  And again you can probably detect a few more flaws in the reduced render settings image, but objectively the difference between the two doesn't seem that great to me.
unzipped posted Sat, 13 May 2006 at 5:54 PM
Here's the reduced texture version - similar results as before (loss of detail), and again the render time was basically the same as the non-texture reduced compromise render setting image.
unzipped posted Sat, 13 May 2006 at 6:21 PM
So I've found the perfect render settings right?  Not so fast!  This image, shot from the main camera at 240 units (I'm working in inches) away on the Z axis at a focal of 100  is rendered with my compromise setting of above - notice the very pronounced aliasing.  Unacceptable!
unzipped posted Sat, 13 May 2006 at 6:27 PM
The fix is upping the Pixel Samples in the render settings.  The manual says 3 is a good default, but trying it out, 4 samples were superior to 3.  All other settings are identical to the ones I posted above.  You can lower this setting as you get closer to your subjects, but if you've got a scene with objects at very different z offsets from the camera I think you can't go lower than 3 (well 4 for me).  I didn't notice an appreciable increase in render time going from 2 to 4, but the entire scene here only took between 3 and 4 minutes to render total, so the impact may be greater in a larger/more involved scene.  I don't think there's much you can do about that though - aliased pictures look crummy so don't waste your time turning out crummy images to save yourself a pixel sample.
unzipped posted Sat, 13 May 2006 at 6:32 PM
Firstly, I know I don't have the ultimate light set up here, but it works well enough for my purposes and for my tests here....
Now to summarize some things I've learned from this:
Min shading rate is the free standing render setting variable that is a serious factor in determining render times. This one is unquestionable – going from 1.0 down to 0.50 doubled render time for the wild hair, and caused similar time increases in all my other portrait tests. A smaller size definitely improved image quality – but by how much? You'll have to decide for yourselves what you can live with, but right now I'm satisfied that 1.0 is good enough for most work I'll be doing at this range.
Now I'm light on reflection/refraction in these tests – only the corneas and eyeballs have any – so number of ray traces could become a bigger factor if there's lots of that kind of thing going on. I usually don't have much of it, so I guess I'll deal with it later if I need to.
Pixel samples didn't become really important until I moved out of close ups and into the main camera shots. Again you'll have to decide for yourselves what you'll be happy with, and it will also depend on what distance you're shooting from, but going with 4 for non-portraits gives decent results – it seemed to take very little longer to render the scene going from 2 pixel samples to 4 pixel samples. For portraits with the face camera 2 pixel samples worked fine for me – when you're in tight antialiasing isn't as big of an issue.
Bucket size is nearly as important in regards to render settings, however it is dependent on other things – anything which impacts the amount of memory available to be exact. Shrinking texture sizes may help here if you are using many different large size image maps in the render. The more memory you can free up, the larger bucket size you can use and the quicker your render will be. One thing I've verified is that for me Poser no longer chokes if I set too high a bucket size. It seems to automatically adjust to a smaller bucket size which will allow it to complete the render. For instance when I set the max bucket size at 1024 it never actually used that buffer size – I think it reverted down to 256. Also when I had the bucket size at 256, it stayed at 256 when I used smaller texture maps/a lower maximum texture size setting. But when I upped the texture sizes and the maximum texture size setting I could see the bucket size ended up being decreased – I think down to 128 – even though I had left the max setting at 256. What this means is you can probably leave your max bucket size pretty high and Poser will adjust down from there to complete the render if it needs to. As I mentioned at the top I'm on SR2 for Poser 6 – so this probably doesn't work in previous releases as I recall getting the magic out of memory popup before when I'd set the bucket size too high.
Maximum Texture size is a tricky thing. You can definitely notice a difference in the quality of the render in terms of reduced detail and sharpness when the textures get reduced – regardless of whether you reduce them by hand yourself prior to rendering or you set your Maximum Texture Size lower than the textures actually are. The render time improvement obtained by reducing texture size was negligible in my testing. This may be due to me not using many different figures/props with lots of textures, but the wild hair itself is a pretty heavy object. I'm leaning towards thinking texture reduction isn't a real player in reducing render time EXCEPT in the case that your textures are causing your bucket size to shrink to unacceptable levels. As mentioned above I've got about 1.5 GB RAM, so I didn't run into this problem. My bucket size never dipped below 128. Shrinking textures prior to rendering, rather than having poser do it, probably saves you anywhere between 30 seconds to a minute per texture – this savings is seen in a faster “loading textures” time and that's about it. For my money the loss of detail, clarity and sharpness is not worth reducing the textures – at least I haven't run into a situation that it would be worth it yet.
In terms of hair, the biggest time killer of all are hairs that use complex material set ups combined with elaborate transparency/alpha maps. The Wild hair has 4 materials used in rendering, the Long Hair Evolution has 3 materials used. However for each material on the Wild hair there are three maps used and one specular node.The Long Hair Evolution materials have 2 maps each and no nodes. Eyeballing the transparency/alpha maps for the two hairs in question, it seems to me that there's quite a bit more and quite a bit more detailled mapping going on with the Wild Hair. I haven't delved deeply into the material settings for the Wild hair, but it seems to me that the extra work required to avoid painted highlights, replacing them with procedural highlights along with the more complex transparency maps cause the user to pay a very heavy price in terms of render time. The Wild hair definitely renders more realistically when everything is on – but is the extra realism worth the extra hour of render time? I know I'll probably only use the Wild hair with it's full material setup only on very special occasions. The lesson here is to pay close attention to the complexity of the shaders you use when there's a busy transparency map happening – and hair is the prime culprit in this area, so use your hair figures and props carefully.
I hope some of this proves useful/educational to some folks around here, and of course I'd enjoy hearing what others have to contribute as well.
Unzipped
Rance01 posted Sat, 13 May 2006 at 6:50 PM
Great thread.  Again, thank you unzipped.  The forums have sort of departed from this sort of real Poser support/knowledge thread and I appreciate all of the time it must have taken to compile all of the data, screen captures and rendered images.
Best Wishes - Rªnce
richardson posted Sat, 13 May 2006 at 7:05 PM
Unzipped, You're probably burned out but, 75% is too much of a reduction for this distance imo (don't call me that,,,lol). Skin, I set from 50-70% depending on distance to camera (full figure view only). > Interesting it did not help speed. This is still relative as I'm sure it lowered memory usage(how many hi-res skins vs low-res skins you can render in one pass). I don't reduce the skin at all for a head shot. < I see in your last post you covered this with bucket size. The "Wildhair", oddly looks much better to me despite the huge reduction. I reduced mine 50% and was still getting artifacting with shading rate at 1.00. Your reduction seems right. Koz hair is conforming (a figure)? Definately too much reduction here. I use 75% of original. It screams for a low shading rate as do most of his. Some displacement, too. One thing, you have RayTrace(2-3) bounces on for what? Reflect nodes on eyes? This is slowing you down, imo. If not using reflect nodes, I'd set it to 0.00bounces. face_off always has reflects on his eyes. Maybe that's why they are in his settings. and yours... And I noticed you have AO off in this run. Turning "visible in RayTracing" off on the hair should have a dramatic decreasing effect in rendertime. I did not hear you mention if it was on/off. All in all a very helpful run of tests. I'll have to be stubborn about the hair texture reduction technique as you really went too low in res with this example. Stewer recommended a 20-50% reduction. I've had spectacular results. Awesome stuff! This is how you get your renders. No more throwing darts...
unzipped posted Sun, 14 May 2006 at 11:19 AM
Quote - Unzipped, You're probably burned out but, 75% is too much of a reduction for this distance imo (don't call me that,,,lol). Skin, I set from 50-70% depending on distance to camera (full figure view only). > Interesting it did not help speed. This is still relative as I'm sure it lowered memory usage(how many hi-res skins vs low-res skins you can render in one pass). I don't reduce the skin at all for a head shot. < I see in your last post you covered this with bucket size. The "Wildhair", oddly looks much better to me despite the huge reduction. I reduced mine 50% and was still getting artifacting with shading rate at 1.00. Your reduction seems right. Koz hair is conforming (a figure)? Definately too much reduction here. I use 75% of original. It screams for a low shading rate as do most of his. Some displacement, too.
For this test I was only concerned with seeing how things affect render time.  I went down to a 512 width on all maps as I figured that would be the minimum you could go down to and still have an o.k. texture, assuming that you would then see the largest decrease in render time possible.  As it turns out even a 75% reduction had a minimal affect on render time, so I'm left feeling there really isn't much point in doing the reduction at all and risking detail loss as long as you're not running into memory issues.  I'm certain a lesser reduction would cause less of a degradation of detail quality, but I'm not certain it's even worth the effort if the goal is simply to reduce render time.
Quote - One thing, you have RayTrace(2-3) bounces on for what? Reflect nodes on eyes? This is slowing you down, imo. If not using reflect nodes, I'd set it to 0.00bounces. face_off always has reflects on his eyes. Maybe that's why they are in his settings. and yours
Yes as I mentioned at one point above, I do use reflection for my eye materials in every render, so I leave the ray trace bounces in - although I actually only have it set to 1 in my final render settings as seen above.  In my testing changing the ray trace bounces had very little impact on the render times.  Now that may change if the scene becomes more full, but I can adjust downward from here if necessary.  Also I would think when using ray traced shadows, the number of bounces would affect the resulting shadows as well, so 0 would not be a good setting in that case.
Quote - ... And I noticed you have AO off in this run. Turning "visible in RayTracing" off on the hair should have a dramatic decreasing effect in rendertime. I did not hear you mention if it was on/off. All in all a very helpful run of tests. I'll have to be stubborn about the hair texture reduction technique as you really went too low in res with this example. Stewer recommended a 20-50% reduction. I've had spectacular results. Awesome stuff! This is how you get your renders. No more throwing darts...
As I mentioned somewhere above, I'm using face_off's realism kit here, and do on almost all my renders.  So the light A/O is off, but the figure itself bears A/O nodes, thus the visible in ray tracing needs to be on, at least for those things that can cast shadows on the figure itself.
Now where is that light set up of yours !?!? ;)
Techware3D posted Sun, 14 May 2006 at 11:16 PM
BM
JD Wohlever
Techware 3D
rty posted Mon, 15 May 2006 at 1:58 AM
Quote - I often find myself wishing there were additional raytrace settings on the lights so that for instance they did only specular and didn't add more actual light to the scene
Easy: Set up a light, then go to the material room and change the light's diffuse color to black. You get a light that only does specular; Very convenient, I use them all the time. Only drawback is they still show as normal lights in the preview, so you have to turn them off while fine-tuning your lighting.
unzipped posted Mon, 15 May 2006 at 1:31 PM
Quote - > Quote - I often find myself wishing there were additional raytrace settings on the lights so that for instance they did only specular and didn't add more actual light to the scene
Of course!  Once someone points out a solution it always seems so simple and obvious.  Thanks for answering that question, I'll have to try that out.
Unzipped
richardson posted Wed, 17 May 2006 at 6:02 AM
Lights have been shipped.
Angelsinger posted Mon, 24 July 2006 at 7:56 PM
Well, I don't know about the rest of you, but I'm not bookmarking this, I'm saving these pages DIRECTLY to my computer. Local copies. Offline viewing. tehehee
Thank you for this, unzipped.
Richardson, you're a friggin' genius.
mickmca posted Tue, 25 July 2006 at 6:30 AM
Mark excellent thread
face_off posted Wed, 26 July 2006 at 6:36 AM
There is way too much info in this post to digest!
Unzipped - the shadows in the post above are perfect.
There are too many points in this thread to comment on at the moment.....other than to say any render and shadow settings I may have provided err on the side of quality (so it's safe to say that you should be able to tweak the settings to get the same quality render at a much faster speed).  For rendering speed - never use infinite lights (if they use depth mapped shadows) - always go with spots.  You can should also stop any ground and wall planes from casting shadows - this reduces the shadow map size requirements.  Shading rate impacts a lot of things - I've recently found that a low shading rate is critical for effect Gather node results.
Anyway - great infor in this post.....
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
