Subject: Using The RTE Encoder
Robo2010 opened this issue on May 03, 2006 · 7 posts
Robo2010 posted Wed, 03 May 2006 at 7:57 AM
Gees, the program looks so simple when using. But I am having problems decoding a freebie file that is in RTE Format. Anyone can explain to me how to decode a RTE file? Pretty Please..
judith posted Wed, 03 May 2006 at 8:36 AM
There should be a readme indicating what file is the seed file (what the file is encoded to).  There are a few decoders out there, here's a clip from Russel Cook's program readme.
3.2 Decoding a file
It's been a while since I've used anything else, each one should have a set of instructions.  It's relatively easy, but can be intimidating when you do it the first time.
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
Robo2010 posted Wed, 03 May 2006 at 9:22 AM
K..I am using the 2.0, and it didn't come with a readme, even in the freebie. All it is in the zipfile is just an exe file. I got it from the RTE website, download section.  I do not see 3.2 anywhere.
Trying to decode trekkiegrrrl's hamster from DAZ's house mouse. I keep getting a message.."Are you sure you want to replace........?" I already had to reinstall DAZ's house mouse. I am wrecking my obj files from trying to decode. :-(
nruddock posted Wed, 03 May 2006 at 9:31 AM
RTEncoder 2.0 is still only an alpha and non-functional (see -> http://www.rtencoder.com/).
You'll need to use 1.01 to be able to do anything.
judith posted Wed, 03 May 2006 at 9:33 AM
Sorry, that isn't Version 3.2, it's from the readme.  I'm behind here, still using Version 1.
Your best bet is to drop trekkiegrrrl an IM if you're having problems with the instructions.  I don't have her hamster or the housemouse.  Sorry I couldn't be of more help.
Robo2010 posted Wed, 03 May 2006 at 12:29 PM
Finally got it done using 1.01. Thanks peeps. I hope I do not have to go through that again.
judith posted Wed, 03 May 2006 at 12:34 PM
😄 The first time is always the hardest.  Of course there are so few things encoded and the time between use always makes it seem like it's the first.
Glad you got it worked out!
