SVicious opened this issue on May 05, 2006 · 6 posts
SVicious posted Fri, 05 May 2006 at 1:27 PM
I had to reinstall photoshop into my computer, but I am having a issue with the fonts available in photoshop, now photoshop doesn't dispaly all the fonts I have in my font folder it use to before I had to reinstall it but for some reason its not displaying all my fonts now anyone know why?
SVicious posted Fri, 05 May 2006 at 3:38 PM
dreamer101 posted Fri, 05 May 2006 at 8:18 PM
What version of Photoshop are you running? The font folder you are talking about is the system font folder? How many fonts do you have installed? Why did you have to reinstall Photoshop? It's hard to tell what the issue may be. Could be too many fonts installed.
retrocity posted Sat, 06 May 2006 at 12:32 AM
dreamer, can't you rename the font list file and force PS to rebuild it??
i know i did it in the past but i'm not sure how it's handled in the newer versions... but then again, it could very well be puking on the "too many fonts"... Hoof has a boat-load of Fonts on his system, i can't remember his solution. maybe i'll search the archives.
retrocity
dreamer101 posted Sat, 06 May 2006 at 10:53 AM
You can delete the font list file from the Program FilesCommon FilesAdobeFonts folder and this will cause your system to rewrite the font list. As retrocity said renaming would be safer. The font file is adobefnt.lst but it might have a version number in it such as adobefnt07.lst depending on which version you are using and which past versions you have used. There could be a corrupt font or font reference since you last installed Photoshop and it might fix your problem.
dreamer101 posted Sat, 06 May 2006 at 12:09 PM
Actually, do a search and delete (rename) all occurrances of adobefnt*.lst.
