Forum: Photoshop
Subject: Texture lighting
Dorie0924 opened this issue on May 07, 2006 ยท 4 posts
Dorie0924 posted Sun, 07 May 2006 at 9:15 AM
In what folder should i place them
and how do they work?
aprilgem posted Sun, 07 May 2006 at 1:05 PM
In "Textures" as PSD files. Black and white works best.
Dorie0924 posted Mon, 08 May 2006 at 4:08 PM
thanks, how do they work?
aprilgem posted Mon, 08 May 2006 at 7:16 PM
Just a guess:
For distortion, white areas in the image push the pixels in one direction. Black pushes them in the other. Gray doesn't change anything
For texture lighting, white areas are "high" and will be lit, while black areas are "low". Think of it as a topographical map with the lighter areas being the peaks and the darker areas being the valleys, and if the sun (the light) is coming from the left, the shadows will be on the right side of the mountains. If you've ever used Bryce or some other 3D landscape generator and fiddled with terrains, it'll make better sense to you.
