StaceyG opened this issue on May 10, 2006 · 91 posts
StaceyG posted Wed, 10 May 2006 at 1:51 PM
Attached Link: http://www.renderosity.com/index.ez?viewStory=13047
Messaging system is back up and converted. Please read the info at the attached link
Thanks
iloco posted Wed, 10 May 2006 at 1:55 PM
Mine is showing I have one new message but when I click on it there is none in the inbox. :)
Is this a glitch that will be fixed.
This is when I am viewing the gallery pages.
Why is the site so slowwwwwwwwwwwwwww. :(
ïÏøçö
StaceyG posted Wed, 10 May 2006 at 1:59 PM
That issue is fixed now:)
iloco posted Wed, 10 May 2006 at 6:35 PM
Thanks for the fix. :)
ïÏøçö
StaceyG posted Wed, 10 May 2006 at 7:46 PM
No problem:)
SophiaDeer posted Wed, 10 May 2006 at 9:49 PM
Hi, I am getting the same thing please.
It says I have a message but there is none.
Thanks.
Best,
Nancy
Nancy Deer With Horns
Deer With Horns
Native American Indian Site
StaceyG posted Wed, 10 May 2006 at 9:53 PM
So its still saying you have one message but you've already "read" all and you don't have any new messages? I know it was doing this earlier as I had the same issue but the programmers fixed and now mine is gone so I am making sure I understand correctly so I can report this still ongoing to the programmers.
Thanks
SophiaDeer posted Wed, 10 May 2006 at 9:58 PM
Yes, I sent myself a memo just to test it. Read and deleted it.
Now it says I have a message when there is none when I go to look.
Thanks.
Deer With Horns
Jumpstartme2 posted Thu, 11 May 2006 at 6:17 AM
I just tested as well..everything seems to be working ok here so far...Sophia, just curious what browser you are using?
~Jani
Renderosity Community Admin
StaceyG posted Thu, 11 May 2006 at 10:18 AM
I have forwarded this thread link to the programmers to take a look Sophia:)
SophiaDeer posted Thu, 11 May 2006 at 1:15 PM
Thank you very much Stacey.
Deer With Horns
SophiaDeer posted Thu, 11 May 2006 at 1:19 PM
Hi Jumpstart,
I am using the MSIE. It seems to be resolved for now. Thank you to all.
Best,
Nancy
Deer With Horns
romanceworks posted Thu, 11 May 2006 at 7:29 PM
We also have a message but nothing there. Also, the old method allowed us to click on username of sender and it took us to their homepage ... the new method allows only the reply to the message with no link to the sender. The old method was very useful because we were able to go to senders gallery, store, etc to make comments or look at products when appropriate. It owuld be most helpful if the new method could allow us to link back to the person sending the message. Carol
StaceyG posted Thu, 11 May 2006 at 8:14 PM
Hi romanceworks,
All the things you mentioned in your post will be just like they were when all the pieces convert and everything is in place. Its just a momentary issue which will be resolved:)
romanceworks posted Thu, 11 May 2006 at 11:01 PM
Great! Thanks for the info. :o) Carol
iloco posted Fri, 12 May 2006 at 7:27 AM
For two days I have tryed to send a person a message and in my sent box it shows there are no messages .
I know this person hasnt received because I have yet to get a reply.
Is this a known issue with new IM system.
ïÏøçö
StaceyG posted Fri, 12 May 2006 at 9:58 AM
You are sending from the new messaging system correct? Just making sure it wasn't an email you sent from their member page.
Thanks
iloco posted Fri, 12 May 2006 at 10:07 AM
Yes I was sending from new message system. :)
ïÏøçö
StaceyG posted Fri, 12 May 2006 at 10:34 AM
I sent you a site mail message testing things:) Please see if you have it and reply back so we will know its all working for you like it should.
Thanks
iloco posted Fri, 12 May 2006 at 4:22 PM
Got it figured out with your help. Thanks. :)
ïÏøçö
StaceyG posted Fri, 12 May 2006 at 5:33 PM
So glad:) Sometimes with change its just a matter of getting used to something different although in this situation because we are in the midst of converting to the PHP things are a little confusing at times. I cannot wait until its all complete and all the pieces are here so that things will flow consistently..
Richardphotos posted Fri, 12 May 2006 at 9:33 PM
it is all well and good but where in the tarnation is the email located? the only way I have found it is when I have had an im. I have looked up and down but do not see a link
Lyne posted Sat, 13 May 2006 at 2:52 AM
I read the new information, looked anxiously at my member options on the side bar, found one that said IM archive...and that was the ONLY link I can see, and used that to get to my message center...where I found all the things I had sent in the past -and posted so unhappily about in the news thread...and of course I deleted them... but ARE THEY GONE?? I mean really gone from your servers, so my privacy is maintained?
So to have privacy, I write a message, send it, and then go delete it from my sent box?
And where/how do I send an IM to someone in a forum thread/posting?? Most forum threads have a IM link near the person's name... I wanted to ask for a IM so I can SEE the new way I am notified, but I can't figure out how to send one to a particular person????
Life Requires Assembly and we all know how THAT goes!
Lyne posted Sat, 13 May 2006 at 2:58 AM
mysql error: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '???' at line 1, occured in query: "select username from member where userid = ???".
okay...I clicked a persons PROFILE...then I hit THE LINK ON YOUR NEW PAGE to send an instant message, and I got the above!?
so... would I be sending an e mail or a message IF I was brave enough to even try with the errors?????????
I tried again...and I was at that person's home page...and I got :
The username entered does not exist.
huh??? is it just that I should not bother till your WHOLE site is done and the pieces are hooked up?? or I have to type the EXACT uesr name in and hope for the best?
AARGGHHHHHHHHHHHHHHHHH!
Jumpstartme2 posted Sat, 13 May 2006 at 3:10 AM
Lyne, try going to the messaging area, then once there, click on 'compose' {if its not already there}
type in your own username {just like it is here, for Im not sure if it is case-sensitive} then send it..then click on the forums page again and you should see a new message where the image I posted is showing it to be.
Let me know if that works :)
~Jani
Jumpstartme2 posted Sat, 13 May 2006 at 3:33 AM
Another thought..{just to be clear} if you go to a members profile page, the first compose box is for an IM, the lower text box is for emailing.
~Jani
Lyne posted Sat, 13 May 2006 at 9:15 PM
Thank you, I'll give that a try and keep in mind that the first area is for a message. I shall go send myself a message! ;)
mejed posted Sun, 14 May 2006 at 10:38 PM
Please bring back IMs, this new system kinda...well...it kinda sucks. (pardon my english). IM
s were fast, and a lot eaiser to use.
StaceyG posted Mon, 15 May 2006 at 6:20 PM
Unfortunately the new site mail is here to stay:( It will work better and quicker once all the pieces are converted over so that you can just click to send someone a site mail instead of having to put type their username in. Hopefully you will get used to it and it will become easier for you to use.
Sorry but we can't change it back
Thanks
ARTWITHIN posted Fri, 19 May 2006 at 2:31 PM
I'm getting the same:
Here is what I see on Site Mail when I go to send site mail to someone:
To:
Please note the "To:" field is blank. This indicates to me that it is addressed to no one. I have to manually enter the user name.
Others must be getting the same thing as I am getting nothing but e-mails from people trying to contact me. No site mail is being used to contact me.
I will have to contact everyone to inform them that I now have their real names and e-mail addresses, and let them know they have to manually enter the username if they want to use Site Mail.
The Site Mail worked until the last 7 days. If you have any further suggestions or comforting words, I would appreciate them at this point.
“Music is harmony, harmony is
perfection, perfection is our dream, and our dream is
heaven”
Henri Frederic Amiel
StaceyG posted Fri, 19 May 2006 at 2:35 PM
I'm not sure what you are saying her Artwithin..When you type someone's username in to send them a site mail you are getting the error message above? I sent you a test site mail to see if I got an error and I didn't
I may be misunderstanding what you are explaining above, if I am I apologize but could you give me some more details?
Thanks
StaceyG posted Fri, 19 May 2006 at 2:42 PM
I sent you a few site mails using various methods and one showing the Send site mail button. Is this what you are using that gives you the error mentioned above?
Thanks
ARTWITHIN posted Fri, 19 May 2006 at 2:46 PM
Sorry Stacey, I'm on dial up and there are now so many different steps to getting somewhere that it takes me some time to get back to you.
I got the 3 Stie mails. I saw the button, and that is the one I use that is giving me the error message.
heaven”
ARTWITHIN posted Fri, 19 May 2006 at 2:47 PM
Here are my steps:
I click "Contact", then the "Site Mail" bar, on the "Compose Mail" screen I see the above "mysql error" message and a blank "To: " field. I have to enter the contact username manually to send the site mail.
heaven”
StaceyG posted Fri, 19 May 2006 at 2:51 PM
Getting with the programmers to see why this is may be happening to some.
Thanks
ARTWITHIN posted Fri, 19 May 2006 at 2:57 PM
Thank you Stacey. I work at night so I have to go to bed now. I will reply to any ebots or Site Mail when I get home from work.
heaven”
tutone1234 posted Fri, 19 May 2006 at 4:24 PM
Hi Artwithin - I'm assuming you are referring to mailing a member from their homepage. This problem has been corrected. Thanks.
Tommy
StaceyG posted Fri, 19 May 2006 at 5:57 PM
Thanks Tommy:) Appreciate you taking care of this so quickly!! You rock it man:)
L8RDAZE posted Tue, 23 May 2006 at 3:13 PM
StaceyG posted Tue, 23 May 2006 at 8:03 PM
Okay great thanks for letting me know. I will inform the programmers so that can see why this might still be happening for some. Can you let me know if you clicked to send the site mail from the homepage, from the profile here under the avatars, from the Messgaing link at the top, or exactly which path you took, LOL.. It will just help the programmers better isolate the issue.
Thanks again!!
marzo posted Wed, 24 May 2006 at 4:04 AM
Hi Stacey, I am having this problem too. To try and clarify, I click on a user name in the comments under one of my images; click on 'Use site mail to contact member' and get
above a blank 'To:' box. I'm using IE6, WinXPsp2.
And as you can see, I'm also getting double lines when hitting
Hope this helps.
How I bled when they said that the rose had no thorns
L8RDAZE posted Wed, 24 May 2006 at 5:21 AM
It happens when I use the contact link under a gallery image and then use the Use Site Mail to Contact Member. I noticed it doesn't automatically insert the members name using this method. Must be an issue pulling from the database.
please note it does work when using a member's profile link from a forum post. (Under the avatar image)
StaceyG posted Wed, 24 May 2006 at 9:47 AM
Thanks to you all for the info!! Have contacted the programmer for a resolution..
StaceyG posted Wed, 24 May 2006 at 10:59 AM
Just out of curiousity, did both of you try this yesterday late or today? The programmer and I both went through the path that you two describe above and it did populate the name and neither of us received the SQL error. Tommy fixed something earlier yesterday I believe is when it was so that is why I'm making sure you both tried this "after" the fix.. Please let me know so we can continue trying to figure this one out:)
tutone1234 posted Wed, 24 May 2006 at 1:41 PM
L8RDAZE,
Can you tell me exactly which member you were trying to message. I'm having a hard time replicating the error so that I can fix it.
I've sent test messages using all of the methods described above and can't seem to produce the error that has been reported.
Thanks.
BAR-CODE posted Wed, 24 May 2006 at 2:44 PM
HEY thats what i got just now my old friend the SERVER ERROR....
I can't use the new IM mail system at all i only get these errors and when i try to sent a IM " i get kicked in the but " and got to reload from the start at the site.
Also i miss 80% of the NEW trheads at the forums of my choice and i have to got to the site to check for new topics ...
I posted this more thatn one time in several forums but don't realy get an answer...
Remeber me saying "its like talking to a door" .... well here is the door again...
Greetz Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
-Wolfie- posted Wed, 24 May 2006 at 2:50 PM
It seems to be down again, or the trial RO was using is expired...
http://market.renderosity.com/mod/sitemail/ - I am getting this:
**Your free trial for the 'sitemail' module has expired.
If you have already purchased a license, please click the button below to activate the module for this site.
No record of completed purchase for 'sitemail' module on this site.
**If you would like to purchase this module for this site, click the "Buy It Now" button below. Be sure to Activate after your purchase.
**~Wolfie~
Helping everyone is the most rewarding failure you'll ever experience.
- Ray Augé (~Wolfie~'s hubby)
Anything is more stable than Windows . . .
--- Even a relationship based purely on sex!
- Pam Augé (~Wolfie~)
No meat was harmed during the making of this TV dinner.
L8RDAZE posted Wed, 24 May 2006 at 7:55 PM
**@tutone1234
**I tried random members...again from the contact link under an image in the gallery.....same SQL error as stated above!
marzo posted Thu, 25 May 2006 at 3:18 AM
Hi Stacey/Tutone,
Just tried again this morning (3.05 CST) exactly as described in my post above and it is just the same. In this instance I was posting to ScrumpyJack. He is a friend of mine and you can 'test message' him if you wish.
Good luck!
Graeme.
AprilYSH posted Thu, 25 May 2006 at 3:31 AM
Got a new problem Stacey...
I sent a message, then before it is read I deleted it. The person still received it. What's with that?
I deleted it because it had incorrect info. I wrote a new message, but the old one still got delivered, plus the new one.
If it allows deletion of unread messages, it shouldn't allow them to be read.
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Jumpstartme2 posted Thu, 25 May 2006 at 6:22 AM
Ive never known a sent message to be able to be stopped once its sent..whether or not the person recieving it has read it or not...once its sent, its sent.
I think that feature is more like a 'read receipt' than anything else.
~Jani
AprilYSH posted Thu, 25 May 2006 at 8:00 AM
"once it's sent it's sent" is only meaningful if the deletion is not allowed.
phpbb forums allow you to edit or delete private messages that have not yet been read.
The easy way out here is not to allow deletion of unread messages, otherwise the system is misleading/poorly designed.
williamsn posted Thu, 25 May 2006 at 10:58 AM
Quote - Hi Stacey/Tutone,
Good luck!
Graeme.
Our team was finally able to duplicate this problem. We can only get it to happen one way. Please don't think we are just shrugging this off. Tutone spent hours on it yesterday just trying to get the problem to HAPPEN. Here's how we finally got this problem duplicated: - Logged out of the Marketplace server (the one with sitemail) - Went to the community side and went to a member's homepage (such as homepage.ez?Who=williamsn) - Clicked on "Send An Instant Message" - On next page, clicked on "Use Site Mail to Contact Member" - It asked us to log in since we were now on the Marketplace server - After logging in, it took us to the Marketplace homepage - We hit the "Back" button to go back to homepage.ez. - We clicked on "Use Site Mail to Contact Member" again - We got the SQL error you are referring to If this is what you are doing, you should know that hitting the back button after logging into a site is always bound to give you errors. After logging in, you should click on "Messaging" and then simply type in the user name in the compose message form. Or, return to his homepage WITHOUT hitting the back button and click on "Use Site Mail to Contact Member" again. Nicholas
-Nicholas
-Wolfie- posted Thu, 25 May 2006 at 11:19 AM
Thanks Nic!
~Wolfie~
marzo posted Fri, 26 May 2006 at 4:01 AM
First of all, I certainly don't think you're shrugging anything off here - I know how difficult it can be to duplicate a problem in order to fix it and I don't envy you guys!
Anyway, this is how I can make it happen:
Rosity front page,
In the drop-down 'Member Options' choose 'My Gallery',
Click on an image,
Click on a user name who has left a comment,
Click on 'Use Site Mail to Contact Member',
and I get the above error.
No back-buttons anywhere.
Graeme.
williamsn posted Fri, 26 May 2006 at 10:24 AM
Could you please give me the username of the user whom you were tyring to contact in this exact example you just gave me? Nicholas Edit: Give me the image you clicked on, the name of the member you wanted to contact, and the first few words of the comment you clicked on. I'm going to try to replicate it to a T. Because I just followed those exact steps (minus having the correct image, username, etc) and didn't get any error.
-Nicholas
marzo posted Fri, 26 May 2006 at 10:41 AM
Quote - Could you please give me the username of the user whom you were tyring to contact in this exact example you just gave me? Nicholas Edit: Give me the image you clicked on, the name of the member you wanted to contact, and the first few words of the comment you clicked on. I'm going to try to replicate it to a T. Because I just followed those exact steps (minus having the correct image, username, etc) and didn't get any error.
Hi Nic, same name as before 'ScrumpyJack' , the image (from my gallery) is 'Global Warning'. His message starts: 'great work, but I would have left the water out . . .' . As I said before, feel free to 'test message' him, he doesn't mind if it helps you to sort this out.
Thanks!
Graeme.
williamsn posted Fri, 26 May 2006 at 11:01 AM
I followed those exact steps, on that exact image, with that exact user, in four separate browsers: Safari, Netscape, Firefox, and Internet Exploer (on Windows except for Safari). I simply did not get this error. We cannot figure it out. All I can say is hopefully once the conversion process is finished and everything's over there, you'll never see it again. Sorry, man. Nicholas
-Nicholas
nruddock posted Fri, 26 May 2006 at 11:23 AM
Attached Link: http://www.renderosity.com/members.ez?Who=ScrumpyJack
If you goto the attached link and click on the "Use Site Mail to Contact Member" button, the error appears.Hint : look in the "onclick" attribute for that button.
cliff-dweller posted Fri, 26 May 2006 at 11:37 AM
I've been following this thread because I've run into this problem a couple of times, too. Just so you know, when I run the test that nruddock set up above with the link to ScrumpyJack, I get the same error message others have experienced. Using IE with WindowsXP.
Check out my full gallery at Cliff-Dweller Artworks
StaceyG posted Fri, 26 May 2006 at 12:47 PM
Well I just clicked on the the link above and then clicked the "Send Site Mail" button and no error? This is so strange.. Maybe the programmers can get it figured out.
nruddock posted Fri, 26 May 2006 at 1:31 PM
Maybe some slightly different HTML gets generated because you and williamsn are an admins ?
StaceyG posted Fri, 26 May 2006 at 2:45 PM
Well I don't think that's it because I have a regular member test account that I used as well and I still didn't get the error and also not all members are getting them only some which is what is strange??? We'll get it figured out and we really appreciate the info to help us resolve:)
cliff-dweller posted Fri, 26 May 2006 at 4:51 PM
Stacey, the other thing you might try, if you can, is to do the test from home or somewhere else other than at work...maybe there is something about being on the Renderosity/Bondware network that makes it so the error doesn't occur??
...just a thought...
StaceyG posted Fri, 26 May 2006 at 6:00 PM
Well today I have been at home, LOL.. It was the last full school day for my son and he had an awards ceremony so I did this at home today and I didn't get the error. I also tried it in the past few days from work and didn't get the error so thats not it either???? I'm at a loss here..but its definitely happening to some and not others we just have to figure out the common denominator I guess??
3dvice posted Wed, 31 May 2006 at 12:34 PM
It seems it's still not fixed. Got the same error message today: mysql error: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '???' at line 1, occured in query: "select username from member where userid = ???". This is what the code of the submit button looked like: input type="button" value="Use Site Mail to Contact Member" onclick="self.location.href='http://market.renderosity.com/mod/sitemail/index.php?userid=???' Used --> artists homepage --> Send IM --> Use Site Mail No history back button involved, and logged in to both sites.
Le cinéma substitue à notre regard un monde qui s'accorde à nos désirs. - André Bazin
StaceyG posted Wed, 31 May 2006 at 12:42 PM
Hopefully this will be resolved soon. If they can't find the issue then it will be resolved regardless when the gallery conversion happens.
williamsn posted Wed, 31 May 2006 at 2:08 PM
Quote - input type="button" value="Use Site Mail to Contact Member" onclick="self.location.href='http://market.renderosity.com/mod/sitemail/index.php?userid=???'
Your giving us that information right there helped us find the problem. Thanks. It is fixed now ... for everyone.
-Nicholas
StaceyG posted Wed, 31 May 2006 at 3:39 PM
Thanks to everyone for providing us with the information details that helped track down this issue.
marzo posted Thu, 01 June 2006 at 3:16 AM
Many thanks Nic, Stacey, Tutone and all. I knew you'd get there in the end!
3dvice posted Thu, 01 June 2006 at 4:59 AM
Just have tried, and it works! Thanks a lot for having fixed this problem! :-D
StaceyG posted Thu, 01 June 2006 at 9:14 PM
It was because of you all being patient and continuing to give us details that led us to the problem. So THANK YOU!!!! Glad its all fixed now.
hewee posted Fri, 02 June 2006 at 4:15 AM
The send message works ok if I click on the profile link below a members name here in the forum. But if I am in the gallery it open up to the email message page. Even if I am at there homepage and click on "Send An Instant Message" it opens the same "Send Email to Member" page. "Send An Instant Message" link http://www.renderosity.com/members.ez?Who=hewee#sendim "Send Email to Member" link http://www.renderosity.com/members.ez?Who=hewee#sendemail They are both the same page but the "Send Email to Member" link just open the same page but scrolls down the page some so you do not see "Use site mail to contact member" or what is above. Was going to post the link I get from clicking on profile below my name in the forum because it seems to open up the site message box ok. But my stats say... User has 39 posts. His or her last post was 2006-04-06 20:19:02. I can not find any of them. Clicking on the "view user's posts" just brings up a search page and even doing a search of my name comes up with nothing. Looks like you have deleted all my post in this forum because the oldest one I see is dated 2006 Apr 18 5:49 am.
hewee posted Fri, 02 June 2006 at 4:23 AM
Even clicking on the profile link in my post above does not work. This link here http://market.renderosity.com/mod/forumpro/member.php?who=133066 takes me to the User statistics for hewee page. But now I know I have a post here because I got one above this post but a search comes up with nothing.
hewee posted Fri, 02 June 2006 at 4:46 AM
Ok I can see my post now but man what a pain in the rear to get around the forum now. Plus the site is soooooooooooooooooo very slow.
danamongden posted Thu, 08 June 2006 at 3:04 PM
Today I'm getting an odd error. I'm being told that I have a new message (which I was kind of expecting), but when I click to go there I'm told that:
No record of completed purchase for 'sitemail' module on this site.**
Any ideas?
chohole posted Thu, 08 June 2006 at 3:08 PM
I too am getting the same message....what gives?
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
bitplayer posted Thu, 08 June 2006 at 3:17 PM
When I try to read my new messages I get a page that tells me I need to subscribe to "Site Mail" (for $199.00!!!). I can't get past that page to read my messages. What's up???
bitplayer
StaceyG posted Thu, 08 June 2006 at 3:46 PM
This has been resolved.
classyladytwo posted Sat, 17 June 2006 at 6:54 AM
I don't know if this is the right place but I have notifications turned off and yet I keep getting double of each e-mail ..... I'm sure others are having the same problem..... unfortunately I had to delete all my fav Merchants because of the over flow......100 e-mails I got alone get within a few hours.
and unfortunately this white background just kills my eyes
Thanks
hewee posted Sat, 17 June 2006 at 2:23 PM
I get a email on my on own gallery when I say thanks to those who posted a comment.
DennisReed posted Sat, 17 June 2006 at 5:02 PM
I've been getting Error
trying to get to my email notifications from renderosity that posts have been made by my favorite artists?????
It dawned on me to insert "excalibur." in front of the address and presto it now works!
ie:
http://www.renderosity.com/mod/gallery/index.php?image_id=1239693
should be
http://excalibur.renderosity.com/mod/gallery/index.php?image_id=1239693
It WORKS!
williamsn posted Sat, 17 June 2006 at 5:04 PM
No, I just clicked on the first link (http://www.renderosity.com/mod/gallery/index.php?image_id=1239693) and it works fine as well (as it should because the galleries and forums have been moved to the www.renderosity.com address). Make sure your cache is clear and that you have restarted your browser. N
-Nicholas
BAR-CODE posted Sat, 17 June 2006 at 5:11 PM
Hi
I have some troubles in the forums.. when i view a message... and check the bottom of the page
It says errors on page..
Then i refresh the page "that takes a longer then the initial page load" the site seems to have troubles loading "internal ccs" or something like that ..when the loading slowsss down to an almost full stop thats whats being loaded ....
I can type when the "error pn page" message is there... and i cant do anything until i refresh.
maybe you got something with this info.
Chris
Chris
wabe posted Sun, 18 June 2006 at 11:39 AM
Well, i now wanted to read the story about the new site mail provided in the link in the beginning of this thread. All i got is this: ######################### Not Found The requested URL /index.ez was not found on this server. Apache/2.0.52 (CentOS) Server at www.renderosity.com Port 80 ######################### Does this mean there is no story behind that? Or that it is so old that it is not from any interest anymore? However, all i can say that i do not get any note anywhere - on any page at Renderosity. I have to go through "Site mail/inbox" to see wether i do have a message or not. Not really better than before i would say. I as well get only now and then email notifications that someone posted in the forum i watch - Vue forum btw. I as well get only now and then - two times only so far - an email notification about the posting of someone out of my favourite artist list. And i found more than those two images i am informed about myself. Since today as well the old link to the Vue forum i have bookmarked long time ago ends on a "page not found" as well. Wouldn't it be just a little more user friendly to give a little more information there? And keep those old pages with the information "page has moved..." for some days? I would have loved to see this really. Result of all this? I have not touched the Marketplace pages since weeks - no interest anymore, i can imagine how much difficulties i would face there. When trying to buy something. All things where my credit card information is involved in i am VERY touchy and right now there are too many unclear issues on this site here. So i buy things somewhere else.
wabe posted Sat, 24 June 2006 at 3:31 PM
No answer on that still? what is going on with the site mail? By accident i found a message today in my inbox - after i went to "site mail/inbox" manually. No motification anywhere, not here at Renderosity sites nor by email. Is it planned to be like that? Is it a bug? Is it recognised by the developer team? Is anybody home?
StaceyG posted Sat, 24 June 2006 at 4:27 PM
There are several threads in this forum regarding the ebot issue. We are still looking into this.
As far as the Site Mail is concerned, if you have any new message you should see in the far right hand side a link that says "YOU HAVE 1 NEW MESSAGE" is this where you are looking as the location for the notification is changed.
I am sending you a site mail so you can tell me if you see the message notification right now I'll send
wabe posted Sat, 24 June 2006 at 4:38 PM
Got it Stacey. Thanks for it. Reason why i have not seen this? I have all the links on my right side so that i do not have to scroll horizontally to see the content - on a small laptop. Therefore this area is simply outside my window normally. Sorry to cause actions without real need.
gumbykat posted Thu, 29 June 2006 at 8:49 AM
When I click on the link http://www.renderosity.com/index.ez?viewStory=13047 , I get the dreaded "Page cannot be found" message. I've tried several times - always with the same result. Help?
Linda
StaceyG posted Thu, 29 June 2006 at 10:12 AM
Attached Link: http://camelot.renderosity.com/index.ez?viewStory=13047
Here is the corrected link since the server changes:)gumbykat posted Thu, 29 June 2006 at 10:20 AM
Thanks, Stacey! I think once the conversion is completed, Rendo will be better than ever!!!
Linda
