Subject: Bitmap special effects from Poser not working after import in Carrara
Wombat opened this issue on May 11, 2006 · 4 posts
Wombat posted Thu, 11 May 2006 at 4:42 PM
Have a prop that works fine in Poser 6. It includes special effects as bitmaps with transparency. If I export such to Carrara they look dull or most of the special effects are gone. Anybody know how to make such work in Carrara?
Think about something like "magic light effects" and such.
Dizzi posted Fri, 12 May 2006 at 5:01 AM
How are you exporting them? You should rather import them in Carrara... And ask in the Carrara forum ;-)
anastasis20 posted Fri, 12 May 2006 at 9:35 AM
Dizzi is right, you would be better off in the Carrara forum, but also theres not enough info in your question:
anxcon posted Sat, 13 May 2006 at 1:21 AM
any work done in P6 for lights/textures IMO is a waste if you plan to export to carrara
as nice as importing may be, no importer can create the exact same over 2 programs
i suggest to import only the objects, then set the mats up in carrara manually
