caranarq opened this issue on May 12, 2006 · 10 posts
caranarq posted Fri, 12 May 2006 at 8:20 AM
I'm having problems with image based lighting.
can someone help me?
The problem is that when I load a HDR probe, it is loaded at a very high exposure, causing also the scene to overexpose. Is there a way to reduce the exposure in the loaded map?
another question:
Is there a way to light a scene using HDR without having the HDR in the background?
Thanks in advance.
you're saying CG sunlight is actually based on a real thing????
bobbystahr posted Fri, 12 May 2006 at 11:14 AM
Wouldn't that be right below the HDRprobe you've just loaded, and i think, labeled exposure or contrast,or both?...also to the right I think you can reload the image as a seperate exposure control, don't have Vue up right now so I'm a bit sketchy on this as this old computer don't render all that fast so I've but looked at that page.
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
garyandcatherine posted Fri, 12 May 2006 at 11:22 AM
I think bobbystahr is right, check your settings and you will find that you can adjust the exposure of your background
caranarq posted Fri, 12 May 2006 at 10:52 PM
hm .... maybe it is another feature V5 Espirit lacks of ........... I can't find the exposue controls
Thanks, anyway
BTW, there's yet another question remaining...
Is there a way to light up a scene using HDR without having the HDR at th background, where sky should be?
bobbystahr posted Sat, 13 May 2006 at 12:21 AM
Once
I see
a sound
and
Sometimes
caranarq posted Sat, 13 May 2006 at 1:16 AM
Wow! there's a wind tag in V5I!!!!
V5E lacks of exposure & contrast controls for img based lighting, also both separate illumination & reflection map.
bobbystahr posted Sat, 13 May 2006 at 9:12 AM
I'm only guessing here caranarq, that Vue5 don't have this page....oh well, maybe a 5'er can help y'out
Once
I see
a sound
and
Sometimes
Cheers posted Sat, 13 May 2006 at 1:12 PM
Can I just add that the Exposure control in V5I doesn't really control exposure; it only controls brightness, which is very different to "exposure" that it is labelled as.
I always re-adjust HDR Images in CS2 or HDR Shop.
Cheers
Twitter: Follow @the3dscene
bobbystahr posted Sun, 14 May 2006 at 3:49 PM
Cheers....good thing to do actually...I realized as much[not exposure] but due to the fact I'm only playin with a demo on an el crappo slow machine I haven't really gone deeply into that editor.
Once
I see
a sound
and
Sometimes
jc posted Tue, 16 May 2006 at 11:31 AM
Good point Cheers!
What can you tell us about 'HDR Shop'?
