xlcorp opened this issue on May 15, 2006 · 7 posts
xlcorp posted Mon, 15 May 2006 at 2:35 PM
Any idea? (smooth polygons doesn't help)
Thanks in advance.
spedler posted Mon, 15 May 2006 at 4:48 PM
Basically, if that's the original skeleton supplied with P6, then I suspect that's as good as it gets. It's a simple model and the only idea I can come up with is to buy a better skeleton :sad:
Steve
Miss Nancy posted Mon, 15 May 2006 at 5:17 PM
even the p4 skeleton hand didn't look that bad IMVHO. I haven't checked, but I reckon you'll find the above hand doesn't even have poseable fingers.
xlcorp posted Tue, 16 May 2006 at 4:05 AM
P5 renders the hand correctly. Then I tried to load the P5 skeleton in P6 - no luck, the hand is just like the one on the picture. So I guess it's bug in P6....
spedler posted Tue, 16 May 2006 at 1:18 PM
Okay, I've looked into this a little more. Here's the render in P5:
and in P6:
What you have to do in P6 is turn on smooth polygons for the hand itself (not just in the render settings) and adjust the crease angle. The above render was with a crease angle of 100 degrees, rather than the default 80.
Steve
xlcorp posted Tue, 16 May 2006 at 3:26 PM
Thanks a lot!
Latexluv posted Tue, 16 May 2006 at 5:49 PM
Weapons of choice:
