Subject: Pantyhose for Miki?
aslaksen opened this issue on May 24, 2006 · 6 posts
aslaksen posted Wed, 24 May 2006 at 6:44 PM
Hi,
For A3 and V3 I can either use the MAT poses or buy some of the pantyhose packages. But what about Miki? Is the way to use the material room and assign some of the jpgs that the A3/V3 pantyhose packages use?
Thanks!
Helmer
Gora posted Thu, 25 May 2006 at 1:08 AM
Im not sure I understand your question.... but if its can you use the V3 & A3 hose textures in the material room on Miki, the answer is no, because the UV templats are completely different. You could try downloading a hose, overlay here (in freestuff) meant for V3, and just adapt it to use over your existing Miki texture in photoshop.
"If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
Steven Wright
aslaksen posted Thu, 25 May 2006 at 1:44 AM
HI Gora,
Ok, thanks. So you're saying to find a Miki  texture and a V3 hose and combine them in Photoshop and then use it as a Miki texture. I haven't tried it before but it sounds doable.
Thanks!
Helmer
Gora posted Thu, 25 May 2006 at 1:55 AM
youre welcome :)
"If toast
Steven Wright
mdbruffy posted Sun, 28 May 2006 at 8:22 PM
Unless your doing the kind of hose that require garters, just change the color of her lower body to LOOK like the color of the hose you want- then you don't have to worry about the fit either.
aslaksen posted Sun, 28 May 2006 at 10:06 PM
Thanks!
I'm new to Poser, and so far I've mostly being using MAT files.
But I guess it's time for me to start exploring the Material Room!
Especially now that I've discovered that some MAT files don't work under Poser 6. :-(
Thanks!
Helmer
