Aery_Soul opened this issue on May 25, 2006 · 44 posts
Aery_Soul posted Thu, 25 May 2006 at 4:26 AM
Thanks,
As Shanim & Siliphiel
anxcon posted Thu, 25 May 2006 at 8:23 AM
you don't just "throw" the SSS on, you have to adjust the settings of it to fit your material
click on SSS in the tree, and you'll see many settings
carrara texture room is a bit more complicated than poser, wish it had nodes
would make my materials smaller :)
if you want fake SSS, theres a thread around 4 months back, i converted realskin best i could
but ofcourse nothing is as good as true SSS, i'd suggest reading the manual atleast :)
lululee posted Thu, 25 May 2006 at 9:47 AM
I do hope this thread continues. I am really interested in working with SSS for Poser figures but am totally lost as how to even start.
Is there a link to your thread anxcon?
cheerio lululee
Aery_Soul posted Thu, 25 May 2006 at 10:51 AM
I have studied and played with Carrara material settings and are fairly happy with the SSS results I have got so far, the one in the pic was an exaggeration to better show my actual problem which is not how the SSS looks but that the various model parts (shins, legs, hip) are clearly visible when using SSS.
The pic I have attached should better explain what I want to avoid: it's the gray areas that match the zone where a body part ends and another starts, it's those that I want/need to get rid of.
Thanks,
ShawnDriscoll posted Thu, 25 May 2006 at 11:47 AM
SSS works best on objects that have no openings. One solid piece is the way to go.
lululee posted Thu, 25 May 2006 at 11:58 AM
Shonner,
What about your procedural SSS shader? Does it need to be 1 solid piece. Also your outstanding gallery image with anything goos. 1 peice too? That is a very nice shader.
cheerio lululee
ren_mem posted Thu, 25 May 2006 at 12:14 PM
Actually, I have found pieces are ok with shader domains. I choked Carrara last night with too many texture maps, but let me see if I can put something up. The sss settings themselves do need to be changed greatly depending on the situation tho.
No need to think outside the box....
Just make it
invisible.
ren_mem posted Thu, 25 May 2006 at 12:37 PM
Just make it
invisible.
lululee posted Thu, 25 May 2006 at 1:09 PM
This gorgeous. I do hope someone creates an SSS shader product. I certainly will purchase it. It would be nice if it had skin texture maps. We could always replace them without own.
For totally procedure ones we could use Dimension3D's 2nd Face to add the makeup options.
It is true. One can only learn so much, especially if we have other jobs.
cheerio lululeee
ren_mem posted Thu, 25 May 2006 at 1:33 PM
Thank you. Just spot lights. Been learning basic lighting..no fancies. You can see the difference. I find just exploring one area is the key...you then get to really understand what you can do. I didn't get C5 til dec and the whole CG thing is new, but it's just fascinating. The texture map is from natasha by michelle, btw. It is free...here at rosity. I did redo the lips in the original map, too much gloss for me then I created highlight, bump, dis maps. It takes alot of tweaking...not something you want to do everytime. You would go mad. I have been playing w/ SSS on another project also. Like Shonner, have spent hours playing with just a hand. :lol: Procedurals don't convey from program to program so that will always be a challenge. Once you start understanding Carrara...you will probably do the work in there. I really like the texture/light stuff and think I will probably start having to make my own textures maps :D However, I gotta get more ram! 1 GB cannot handle all that too well.
Just make it
invisible.
ren_mem posted Thu, 25 May 2006 at 2:10 PM
Just to clarify "pieces" might be a problem. Have only experimented so much. That is a cr2, via native. I haven't worked with pz3 and I don't use poser so I can't say there isn't a difference in the way the program perceives the file. However, some settings in SSS are gonna be a problem, depending on what you are doing.
Just make it
invisible.
ShawnDriscoll posted Fri, 26 May 2006 at 1:43 AM
Quote - Shonner, What about your procedural SSS shader? Does it need to be 1 solid piece. Also your outstanding gallery image with anything goos. 1 peice too? That is a very nice shader.
My model was more than one piece. So I had SSS turned off for those skin renders. I tried shader domains on one whole model to apply different shaders, but Carrara treated each domain as a seperate object when rendered and SSS wasn't having any of that.
My plan now is to make body whole and just paint it in Hex 2. Then use SSS on it.
ren_mem posted Fri, 26 May 2006 at 3:47 PM
Probably the domain issue is going to be a bit unpredictable, but sss in carrara has a bit of that anyway. I am finding the sss pretty much overrides other settings a bit too much. Mine are divided into sub-domains. I think better shader handling like grouping and an option to treat as one object or one domain would be very handy. Having no way to replace or group shaders and having to apply them all again is just nutty. I am finding C5 choking on lots of textures. I know memory will help, but I hope it resolves it. Seems like the page file climbs then doesn't come back down in these situations. Once it hits about 1700M it can stop responding. I have a gig. Maybe a leak. Maybe related to the way the texture cache is also being used.
Just make it
invisible.
jrabbit posted Wed, 31 May 2006 at 12:00 AM
The problem is simple. The refraction index and translucency are too low. Where mesh densities change or one ends and another begains the SSS is calculated at ratios to match. Also Carrara is funny lower numbers in some setting boxes actually make things stronger. A little SSS goes a long way. Objects do not have to be solid or continuos to get proper SSS but the settings are variable according to light and object size.
Here are a few picture examples of my SSS setings. I am using the same 3 point light in all 3 renders. One indirect in front 70%white a bulb in front on the floor golden 55% and a blue bulb back light at %70.
jrabbit posted Wed, 31 May 2006 at 12:01 AM
jrabbit posted Wed, 31 May 2006 at 12:02 AM
jrabbit posted Wed, 31 May 2006 at 12:18 AM
I apply the same SSS settings to the skin layers required. If you go say 12 on tralucency and 8 on refraction index you will get problems (blow out and drop off) like you've shown because the SSS in each object section tapers in intensity with light direction valume ect. Like this warped Klien bottle example.
jrabbit posted Wed, 31 May 2006 at 12:20 AM
ShawnDriscoll posted Wed, 31 May 2006 at 2:07 AM
Which one do you personally like. The hard setting or soft? They both seem good to me.
I'm going to try your settings on my female's parts and see if the seams don't show.
jrabbit posted Wed, 31 May 2006 at 2:33 AM
I start with a soft setting and adjust it for my light rig and needs or goal. I just built a blank shader with the soft SSS setings , added it to my material tray. Than I copy past on each skin node. Takes like 3 minutes to set up. Leave out eye parts nostrals . Unless you want to get fancy on the eyes. Here is a face shot with HDRI global on. Takes maybe 2 minutes to calculate than the render takes about another minute.
ShawnDriscoll posted Wed, 31 May 2006 at 2:41 AM
Were you using the same or different SSS settings for the head and body above?
jrabbit posted Wed, 31 May 2006 at 2:47 AM
The same , hard settings. There is a slight variation in color caused by light placement. If I raised the front bulb light the highlight and shadow will move back brightening the face. as the cutoff shadow is right below her chin.
ShawnDriscoll posted Wed, 31 May 2006 at 3:01 AM
I'm using the same SSS settings for my head and body and getting different colors that don't match. It was worth a try though. SSS really does need to have one solid piece for a female body for things to work right, instead of using different volumes of objects.
jrabbit posted Wed, 31 May 2006 at 3:10 AM
jrabbit posted Wed, 31 May 2006 at 4:13 AM
anastasis20 posted Wed, 31 May 2006 at 9:13 AM
ShawnDriscoll posted Wed, 31 May 2006 at 1:28 PM
Jrabbit's and Ringo's heads both suffer from composite skin. Just like my figures do that have seperate head objects. One though could just keep adding more and more lights to try and hide the fact, but then your skin ends up glowing orange as a result.
The best way is to use one complete body object (minus the eyes and teeth).
jrabbit posted Wed, 31 May 2006 at 4:46 PM
Shonner ?
Ringos example sure doesn't show him applying to the whole body so of
course there is an obvious seam deference. That was an example of setup not final product. He has a final on Eovia's gallery.
I'm not sure the look your after ? My example
is harsh , I did not take a moment to edge blend the lips but that wasnt the question. I could normalize the gradient across the surface by raising my values.
That would make the skin more monotone from edge to center. Much less dramatic. simple adjustments in your SSS levels can make it fit the look that fits you. We all have different concepts of what look makes our own personal style.
The original question was how come AS Shanim is getting those gray joints. The
answer is raise the refraction index and translucency to higher numbers. Clearly
there is no seam problem in my render.
Anastasis20 your example tests in your
gallery are super !!
Eovia says the algorithms for there SSS are based on the
same mathematics as the high end software. I believe this is accurate. Regardless
if you use a $4000 package or Carrara you can achieve the results your after if
you work with the software . Guys and Gals do it all the time with and without
solid models.
Here are a few SSS examples of how much control we can get. The bottle is a solid object , the lights
are the same 3 point in all renders. Note the harsh bottom on the top row right. The RI controls that blending. you can see as you go through the row and I bump it down we get seamlike effects.The transluceny controls the depth and size of the highlight facing the light source and camera position. If we animate the object the SSS moves on the surface following the light and camera.
ShawnDriscoll posted Wed, 31 May 2006 at 4:54 PM
Try your render with just one light behind her with GI turned on. Then you'll see seams if in fact you have multiple body parts and have the same SSS values assigned to each.
jrabbit posted Wed, 31 May 2006 at 4:55 PM
ShawnDriscoll posted Wed, 31 May 2006 at 5:14 PM
As Shanim is telling us about an apple and you're showing us oranges unfortunately.
anastasis20 posted Wed, 31 May 2006 at 6:05 PM
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2463500&ebot_calc_page#message_2463500
Hi jrabbit (thanks), The skin texture tests were done in Carrara 4 before there was SSS. The link goes to a thread where I illustrated some of the tricks I used to get that shader set up - plus the fake SSS (bitmap in the glow channel multiplied by red colour, use the texture map brightness slider to adjust the intensity. I think it was roughly the same time as Shonner was working on his procedural skin shader - a great example of how to mix things together & how complex a shader Carrara can create. Mine is more bitmap based, but all the mixers are procedural. And Gwynhale also developed a good looking procedural skin shader around that time as well. Skin shaders are one of those CG things that turn up every so often for any 3D software. And now its SSS turn - good thing too, the manual isn't much help beyond a brief description of the functions. I'm still experimenting with incorporating SSS with I've put together so far.anastasis20 posted Wed, 31 May 2006 at 6:11 PM
As Shanim, could you show us what it looks like at the intensity you would normally use? You did say it was an exaggeration so we could see it. I use Miki & Koji and only have to worry about the texture seam where the neck joins the body - I've designed some dynamic clothing for both & and they all have high collars so I can't see if it does it to those figures. I'll try a nude render and see if it happens to me as well, I'll let you know what happens.
ShawnDriscoll posted Wed, 31 May 2006 at 6:32 PM
Quote - Gwynhale also developed a good looking procedural skin shader around that time
I remember Gwynhale's skin. Great stuff.
jrabbit posted Wed, 31 May 2006 at 8:32 PM
Not at all trying to show oranges. My silly chart just simply shows how increasing settings on the SSS change the surface look. The extreams high and low. The top row clearly shows the bandnig increases as SSS is jacked higher.
this front render is full GI on there is a light in back and i'm using hdri as well. Still no seems. What is important as with any render is how the lights are set. Again SSS responds to light color , intensity, and placement. In fact the 2 tone klien bottle is just an orange SSS on a green phong shader. If I use a red light the SSS highlights will show nice orange , but a blue light will bring out the green base color for example.
First I choose my lighting. Next import the character with texture maps cr2 or pz3. Add the same SSS settings to each skin node. Leave the texture map settings alone. Make sure to use a darker SSS color , i'm using deep red. Bright colors will over bloom the SSS. Do a test render. If its to strong either lower the lights or raise the #'s on the SSS settings. For a contunuous mesh The SSS settings must match and the RI cant be set to low.
The settings are not carved into stone. As you can make a SSS shader that will look different on 2 identical objects of different size rendered in the same scene. Thats what the scale setting is for. But I usually ignore it and build my shader to fit the object and lighting. If I ran into the problem you have not overcome I would adjust the diffuse and RI to fit the lights and the scene. If Diffuse is to high than the bright tansmitted areas will be over kill , if RI is to high than the end of an object part opposite light has a more abrupt dark band. These settings have to be balanced with the light. You will get the same bad results if its a solid object or a group if you go to high. just look at the pink klien bottle thats solid but as I jack up the SSS the banding gets really strong.
This is really simple not a bug or problem. simply observation and adjustment. You dont need much SSS to get some color in the skin without going to the extream you make the object so translucent the polygon density begins to reveal itself at its ends. Than proclaiming it doesnt work :)
Anastasis20 yeh I remember that. I've been using Carrara from when it was raydream. I own lightwave as well for 7 years. Really dont use it anymore as Carrara will get you to the same places just different roads. Plenty can be learned from brazil , vray max maya forms that can be incorporated into carrara.
anyway where beating a dead horse. It does works very easy.
ren_mem posted Wed, 31 May 2006 at 10:48 PM
The sss really does have a lot to it. I was doing experiments isolating each setting and they do really make a diff. It's amazing how many ways you can change it. How much refraction are you using jrabbit? You are likely to only deviate your settings only slightly if at all tho. Only certain domains this would really make sense with. I suppose it is like any lighting it can get bad real easy. So far I have not been having any pieces issues. I did find a little goes a long way.
Just make it
invisible.
ShawnDriscoll posted Wed, 31 May 2006 at 10:59 PM
As Shanim, what method did you use to import your figure into Carrara? TransPoser or Native? I imported just now using Native and then set SSS the same for each skin shaders (head, neck, scalp, forearms, legs, hands, feet, lips, and the like). No seams when rendered. This was a Poser 6 figure that Carrara 5 needed the Runtime folder path for to import it in native mode.
Anyway... the resulting figure imported into Carrara is a figure whose body is made up of "one complete mesh" with different skin shaders pointing at different UV maps on it. This is why SSS works for jrabbit's figure because his figure is one volumetric object which SSS loves. I'm rendering a Victoria 3 figure now on my sloowwww P3. Her eyes take forever to render. I'll post pics.
ShawnDriscoll posted Wed, 31 May 2006 at 11:37 PM
ShawnDriscoll posted Wed, 31 May 2006 at 11:39 PM
ShawnDriscoll posted Thu, 01 June 2006 at 12:34 AM
I imported again using TransPoser this time. SSS worked fine, though dragging the SSS setting of one parametric map to the many other parametric map shaders in TransPoser's layers list was a killer. Importing the figure as an OBJ and then applying the same skin shader to the body parts resulted in seams and different scaled volumes using the same SSS values showing different SSS output.
jrabbit posted Thu, 01 June 2006 at 8:13 AM
Well Shoner I copy past in the shader tree my SSS node it takes less than 3 minutes to get through the tree. Most of my renders use SSS on vicky steph or Aiko ,and the girl. Without seams ! Look at my renders , Eve4 , patchouli ,light dance , mg2006 , mauriella ,ankaki,spacebiker. Each has a different skin quality depending on the look I was after but all use SSS in the way I have explained.
ShawnDriscoll posted Thu, 01 June 2006 at 11:54 AM
No seams because Carrara treats PZ3 figures as one mesh. OBJ figures are another story.
anastasis20 posted Thu, 01 June 2006 at 2:37 PM
For As Shanim:
Full agreement with Shonner - I rendered Miki (naked) to see what would happen and I got no seams at all. I imported the figure into Carrara using Transposer - that might be what you need, give that a try.
ren_mem posted Thu, 01 June 2006 at 5:38 PM
I think AS was deliberately doing that and appears based on some extreme settings as jrabbit said may just show seams. I have only used native and all are shader domains...not layers lists, but no seams unless I really alter the domains. The gradient usage there definitely seems key. Cause if you alter a domain, of course, it would look different and not blend naturally. Haven't really seen this with same reasonable settings tho.One thing is sure...the SSS is pretty complex and amazing tho.
Just make it
invisible.
