Forum: Vue
Subject: Vue 5 Infinite keeps crashing
deadman67 opened this issue on May 26, 2006 · 15 posts
deadman67 posted Fri, 26 May 2006 at 4:06 AM
when i start upVue 5 Infinite **it keeps crashing just after the splash screen comes up anybody know what i can do to fix this thanks
wabe posted Fri, 26 May 2006 at 4:21 AM
Sounds like you have a conflict with another application running in parallel. Try to have absolutely nothing running in parallel to see wether this changes something.
And maybe by accident the E-on anti-pirate strategy hits you. This makes the application crash constantly. You should contact E-on technical support when you still have the crashes without any other program running in parallel. Only they can help you on that then.
deadman67 posted Fri, 26 May 2006 at 4:23 AM
so are you saying to try shutting down some running programs the try again?
wabe posted Fri, 26 May 2006 at 4:30 AM
yes exactly - as a first try.
deadman67 posted Fri, 26 May 2006 at 5:33 AM
well that did not work i'l currently doing a reinstall of vue i had un installed some programs mayby there was some shared files that got deleated.
wabe posted Fri, 26 May 2006 at 5:41 AM
ok. If it still is not working you should contact e-on technical support.
deadman67 posted Fri, 26 May 2006 at 5:45 AM
ok thanks
FuzzyVizion posted Sun, 28 May 2006 at 2:06 AM
dead,
I had the same problem...  it crashed on me when opening it over and over... a re-install should fix it... but...
if you are able to click on the 'show tutorials' button before it disappears, then go to File>options and reset your open GL in VUE to 'software' or turn it off ... then close out and re-open ... hey, I dunno, but it worked for me...
then I just turned OpenGL back to Hardware Accel... after it opened fine.
bizaar but true.
btw - VUE has crashed on me over 95% of the time I've ever used it.  All I can say is - save often!
wabe posted Sun, 28 May 2006 at 3:46 AM
Oh, one additional thought. Do you maybe have a dual monitor graphic card? I have problems with Vue on one of our Windows machine (Windows only, Mac does not have this problem) with such a card. The solution there is to start Windows/graphic card in single monitor mode.
deadman67 posted Tue, 30 May 2006 at 8:40 AM
this is as far as it gets
FuzzyVizion posted Thu, 01 June 2006 at 12:40 AM
that sucks.  sorry... I guess you're a ... err... deadman.
Phantast posted Thu, 01 June 2006 at 10:01 AM
One strange problem I had involved some sort of clash with the DivX codecs. I installed some DivX software, and then Vue wouldn't run. It wouldn't even show the splash screen (incidentally, should you be posting your registration code like that?). Just nothing happened.
I uninstalled the DivX package, reinstalled Vue, and then it worked again.
deadman67 posted Thu, 01 June 2006 at 7:47 PM
i never thought to block out the reg code but i trust you all to not to give it out .
iloco posted Thu, 01 June 2006 at 8:53 PM
deadman67,, Let me give you little advise.   Don't trust anyone on the internet  unless you know them personaly.
 Remember the world has access to these forums. :)
ïÏøçö
GrassHopper1 posted Sun, 04 June 2006 at 5:40 PM
A common problem. There is always a lot of useless programmes automatically running on the hard drive. Unfortunately the only way round it is to end all these programs before running Vue and this useally tends to have to be done every time you restart the computer. I tend to just leave it on though! This then should help free up memory as this seems to be the problem - memory space. Also helps to have 1.5gig memory on your computer.
