YourFantasyDream opened this issue on May 26, 2006 · 8 posts
YourFantasyDream posted Fri, 26 May 2006 at 3:03 PM
Good Afternoon All,
Can someone tell me how to remove the nostril glow on my V3 caracter? Im running DAZ 1.2.0.1
bagoas posted Sun, 28 May 2006 at 11:08 PM
Can you give an example render showing it?
markschum posted Sun, 28 May 2006 at 11:16 PM
there is a no-glow nostril prop available , another way is to check the shadow map size. I dont know if you can do that in Daz Studio
YourFantasyDream posted Mon, 29 May 2006 at 1:58 PM
the glowing nostrils are in this render... http://www.renderosity.com/viewed.ez?galleryid=1227163&Start=1&Artist=YourFantasyDream&ByArtist=Yes
bagoas posted Mon, 29 May 2006 at 3:50 PM
It looks as if there is some sort of 'ridge' around her nose. I assume this is V3RR LE. Did you apply a morph there?
Kerya posted Tue, 30 May 2006 at 12:05 AM
Maybe this helps:
http://www.morphworld30.com/
AestheticDemon posted Wed, 31 May 2006 at 10:25 AM
Easiest way to reduce Chernobyl Nostril Syndrome is
Render with shadows on
Set a darker diffuse colour for the nostril material, on your surfaces tab
Use a darker specular colour there as well.
YourFantasyDream posted Wed, 31 May 2006 at 12:51 PM
Thank you all for the great advice!!!!!
