Subject: mouth
mambru opened this issue on Jun 01, 2006 · 10 posts
mambru posted Thu, 01 June 2006 at 3:42 AM
since I can make to change the parameters of the mouth so that it smiles, teaches the teeth or simply it opens the mouth?   As is that parameter?
ashley9803 posted Fri, 02 June 2006 at 1:07 AM
I would love to assist you mambru but I think you will need to make your request a bit clearer. You may need to have someone translate your message for you if you don't speak English well.
pleonastic posted Fri, 02 June 2006 at 2:09 AM
yes, you can.  you need to select the head of the figure first.  then look at the parameter panel -- you will find various morphs there.  exactly what morphs there are depends on the figure, but the poser 5 and 6 people all come with basic head morphs which you can use to make them smile.
i highly recommend reading the manual that came with poser, and to follow the tutorials.  what is your native language?
mambru posted Fri, 02 June 2006 at 4:00 AM
ok. mi lengua nativa es el español. y queria saber q parametros he de tocar para q pueda habrir la boca de mi modelo y hacerla sonreir enseñar los dientes ect.
Os agradeceria que pudierais contestarme en español.
Miss Nancy posted Fri, 02 June 2006 at 1:28 PM
Attached Link: http://www.renderosity.com/members.ez?Who=Casette
env un mensaje al casette y podrayudarle mas mejor que los otros. usted debe utilizar el "smile dial", si usted tiene una versi inglesa. tambien utilize los "mouth open" y "mouth closed" paretros.
mambru posted Sun, 04 June 2006 at 5:56 PM
miss nancy, pasame tu hotmail
Miss Nancy posted Sun, 04 June 2006 at 7:14 PM
no lo tengo - que ltima! no quieres hablar con casette? el sabe mucho m que yo, en todos las cosas de 3d.
mambru posted Mon, 05 June 2006 at 5:04 AM
dile a casette q si me quiere pasar su hotmail.
Tambien habla español??
No encuentro los parametros q me dijistes. Pincho en la cabeza y no me salen ninguno de esos parametros, e intento seleccionar solo la boca pero me parece q no se puede.
Me puedes ayudar???
Gracias por adelantado
Miss Nancy posted Mon, 05 June 2006 at 1:10 PM
casette tiene un grupo en espal (en otro sitio, no puedo discutirlo) y en ese grupo hay unos expertos en "poser". la respuesta a su pregunta implica la "inyecci del morph", y no sexplicar eso en espal. si no encuentras esos morphs, debes cargar esos morphs de un "morph injection file" que sea vendido por "daz".
dolphing posted Mon, 05 June 2006 at 1:40 PM
pincha 2 veces seguidas en la caveza y salen los parametros  y si asi no salen solo ve a window y alli pincha y en el menu selciona parametros ;y alli encuentras todos los morph de la caveza incluyendo la boca ,seleciona uno .por ejemplo el smail y subelo de numeros haciendo girar esa ruda que ves alli, luego selecciona otros que covinen con este pues las expreciones las haces tu mediente covinaciones de estas.
