BAR-CODE opened this issue on Jun 02, 2006 · 9 posts
BAR-CODE posted Fri, 02 June 2006 at 6:38 PM
I try to make an outfit ...i got the basic done and there are good Tut's for the basic part.. they helped a lot.
But now.. How do i make the detail on the clothes... like a pocket or a zipper buckle's things like that.
I don't mean how do i make em' i wanna know how to put them all together...
Do you work on the basic object or cut in it or or or ?!!? is there a bit more advance Tut anyware?
Or is anybody willing to help get me going again ?
I see so many clothes with great details on them ... i wonder how they make em... all together.
I hope this makes sence otherwise people start to point me to "how to make a little skirt for V3 " tuts again ... but that part i got :}
Thnx for any help advice etc etc
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Realmling posted Fri, 02 June 2006 at 7:06 PM
You might want to consider downloading the Freebie SWAT uniform from planetvixens.com and taking a look at it.
Certain details could be modeled in, but if you start to worry about poly count, you could also probably take care of them with displacement maps.
I have to dash off for work, but I think I have some tutorials stashed here and there I can dig up and see if they'd be of any use.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser
goodies and so much more!
pleonastic posted Fri, 02 June 2006 at 7:56 PM
looks good already! you have a real talent for modelling.
which modelling program? are you one of the new hexagon converts? if so, there is a great camera modelling tutorial at eovia3d.net that shows how to make a lot of fiddly detail. i think that might teach you everything you need to create greater clothing detail.
pockets i would probably model, but not an actual zipper. way too many polies. Realmling is right, use displacement maps for that.
Neyjour posted Fri, 02 June 2006 at 9:24 PM
I don't know anything about modelling, but just wanted to say that this is looking really good so far! I especially love the design of the helmet!
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
thefixer posted Sat, 03 June 2006 at 3:14 AM
Wow Chris this is superb! Don't forget to throw it my way when you need it trying out
We'll be seeing you in that top merchants list soon, of that I have no doubt!!!!!
Injustice will be avenged.
Cofiwch Dryweryn.
BAR-CODE posted Sun, 04 June 2006 at 7:08 PM
@realmling
I just loaded the BVH swat file ..and i learned a lot just by looking at it... that was a good idea
Euhhh OK what is it and how does that work in HEX and where can i learn it and and and and...
did i mention i dont have a clue what that is :}
So pleaaaaaseeee explain why and how etc etc and i'll put you in my will..... :-}
Chris
Chris
svdl posted Sun, 04 June 2006 at 9:08 PM
A displacement map is a grayscale image that you can apply to the model just like a texture map. The lighter an area of the displacement map, the more the surface of the model gets pushed out. The main difference between displacement and bump is that a bump map creates an illusion of dents/bulges by changing the color of the pixels, while a displacement map actually alters the 3d model. The difference is plainly visible at the edges of the model.
If you want to see what a displacement map does, download the free gargoyle head by stonemason. The base model is fairly simple, all the details like the warts and so are added using displacement maps.
I don't know Hexagon, so I can't tell you how it works in that app. Poser 5 and 6 support the use of displacement maps; they're very useful.
There's a tutorial in the Poser tutorial section here about making realistic water. It also uses displacement maps. It might help you understand what they're about.
BAR-CODE posted Mon, 05 June 2006 at 5:32 AM
Ahh ... dumb me... the folds in the out as it is on the image are done by a displacement "pen"
Thats the way i made the clothes to look like it real...
And im pretty sure there is a way of putting a disp. map in hex..
I'll play with it and see what's what and how.
Thnx SvdL for the explaining .
Chris
Chris
ccotwist3D posted Mon, 05 June 2006 at 7:35 AM
For seams you need a depression, fold, etc. Add a few edge-loops around the area that needs a seam, and keep them compact. Look at a pair of your own pants or article of clothing you designed on paper, and make the depression or fold using the edge-loops.
The zipper could be comprised of many overlapping primitive squares, or modeled.
Sebastian
