Subject: 3D Max to Poser
Davaris opened this issue on Jun 02, 2006 · 3 posts
Davaris posted Fri, 02 June 2006 at 8:08 PM
Is it possible to export 3D models from Max so Poser can read them? What I want is the models to be correctly textured so I can use them in Poser straight away.
I have seen the 3ds max Plugin Body Studio 2.6 but in their description they only talk about animations.
Evanara posted Sat, 03 June 2006 at 12:20 AM
Poser can read 3DS files and they should be correctly textured (as long as they have received an uvmap in max).
You could also use the MaxtoObj plugin to generate an OBJ file.
Davaris posted Sat, 03 June 2006 at 2:41 AM
Thank you very much for your help. I was using the plug in you mentioned but wasn't using it properly. :)
