Grayhem opened this issue on Jun 07, 2006 ยท 6 posts
Grayhem posted Wed, 07 June 2006 at 8:04 AM
When you render your animations in Vue5 using animated poser figures, will the wind effect in Vue act on the Poser models hair & clothes etc?
impish posted Wed, 07 June 2006 at 10:36 AM
I'm sorry to say the answer to your question is no it won't.
Grayhem posted Wed, 07 June 2006 at 10:38 AM
can you simulate wind within Poser, which will then be transferred across in your poser animation?
wabe posted Wed, 07 June 2006 at 10:39 AM
Maybe we can add - wind and breeze is only available for SolidGrowth plants. And those are the ones with the extention .veg.
vince3 posted Thu, 08 June 2006 at 8:27 AM
you can create wind in poser by using the "create wind force" option,from the objects pull down menu!! this will give you a little fan to place in your scene(you must adjust turbulence and range throughout your animation to get gust effects or a rippling breeze!!) this will work for dynamic hair,but will only look right if you also use dynamic clothes!! otherwise you could use say Kozoburo hair and implie a breeze by adjust it forward and back and left and right throughout your animation!!!! i imagine if you go down the dynamic hair route though that it will be an extreamly long render!!!!!good luck!!!!!!!!!! would like to see the results if you manage to pull it off!!!!!!!!!
Grayhem posted Thu, 08 June 2006 at 12:19 PM
Thanks for all help!
Much appreciated!
