Forum: Poser Technical
Subject: Rendering problem in New window only
siliconmage opened this issue on Apr 03, 2001 ยท 4 posts
siliconmage posted Tue, 03 April 2001 at 9:46 PM
Has anyone experienced a problem with poser refusing to render properly into a new window, but rendering into the main window OK? The problem shows up as vertical lines; as the render fills in from bottom to top, at some point the rest of the image fills in with vertical lines with the same colors as the very last successfully rendered horizontal scan line. It seems to be related to various mesh object props, poser figures by themselves render without problems if no props are added to the image. The rendering always fails as it starts rendering one of these props. I suppose the prop .obj files could have been corrupted somehow, but many of them do this and they are in many different directories, and why just the New window and not the main? Fooling around with different backgrounds, resolutions, and anti-aliasing has no effect. The only recent software changes is the installation of Zone Labs Zone Monitor, any known issues with this vs. Poser? I am running poser v4.0.3.126,500MHz PIII, 128 MB RAM, Win 98. Shall I just forget it and re-install poser? Thanks for any insights you all may have...
