Moebius87 opened this issue on Jun 09, 2006 · 6 posts
Moebius87 posted Fri, 09 June 2006 at 10:33 PM
Attached Link: Moebius87's Store
Previously released collection of seamless tile texture images...
Mind Over Matter
"If you don't mind, then it don't matter."
Moebius87 posted Fri, 09 June 2006 at 10:43 PM
**Möe's Mixed Materials: Volume Four**I am very pleased to present the latest addition to my series of seamless tile images.
This is a collection of twenty-four (24) images in high resolution (1024 x 1024) of real world texture surfaces. These images are created to tile both vertically and horizontally, and are designed as "large scale" surfaces suitable for use in architectural visualizations or high detail renders.
This particular collection has brick wall samples taken from Melbourne, Australia; ground surfaces taken from Siem Reap, Cambodia; assorted Venetian plaster samples taken from a certified stuccatore; and cement samples taken from the driveway of a fuel pump station almost three hundred meters away from my place.
Cheers! — Möe
Mind Over Matter
Moebius87 posted Fri, 09 June 2006 at 10:48 PM
Here's a sample of how well these samples perform in actual renders...By the very nature of what a seamless tile is all about, we all know that there are going to be repetitions in the texture — simply because it does tile. My solution is very simple... sample them big so that when they repeat they won't do so obviously... and also control the sample so that inherent repetitive elements are controlled.
Cheers! — Möe
Mind Over Matter
Moebius87 posted Fri, 09 June 2006 at 10:55 PM
Previously released collections...Mind Over Matter
Moebius87 posted Fri, 09 June 2006 at 10:58 PM
**Coming Soon...**Volume Four should be available in the Renderosity Market Place by the end of the month.
Cheers! — Möe
Mind Over Matter
stonemason posted Tue, 20 June 2006 at 7:19 AM
