vxg139 opened this issue on Jun 16, 2006 · 8 posts
vxg139 posted Fri, 16 June 2006 at 2:29 AM
Hi,
I would appreciate your advice on how to improve rendering of the Kozaburo's "Short bob" hair...
post render (in Poser 4 mode) I get this somewhat fuzzy image...
http://img227.imageshack.us/img227/7582/imagea17he.jpg
Thank you in advance...
Cheers
vxg139
rockets posted Fri, 16 June 2006 at 6:16 AM
Do you have anti aliasing turned on?
My idea of rebooting is kicking somebody in the butt twice!
BrokenAngel9 posted Fri, 16 June 2006 at 9:14 AM
I do believe there was something on Koz' page, regarding Poser5/Poser 6 renders...I see if I can remember the gist of it....ah yes, you need "texture filtering" switched on for the firefly render, not sure if that affects the P4 render engine as well?
Darboshanski posted Fri, 16 June 2006 at 9:23 AM
BrokenAngel9 is correct you must have the box marked "texture Filtering" checked in order for the hair to look right in P5/6. As a matter of fact I think this goes for all the Koz hair props. If you are rendering using the p4 render engine this would not apply. But make sure that you have the "Anti-Alias" option checked.
Micheál
randym77 posted Fri, 16 June 2006 at 12:11 PM
Attached Link: Rendering hair
Don't use Texture filtering. It will eat up memory like crazy, and may do bad things to other textures in your scene.Instead, lower the shading rate. (Of the hair, in Properties, and in your Render Options.)
This will slow the render down, so you might want to wait until the final render. I use a shading rate of 0.01-0.05 for Koz's hair.
See the link for more details.
vxg139 posted Fri, 16 June 2006 at 12:39 PM
Thank you guys for the replies....
I use P6 but prefer rendering in P4 mode (since it is much faster). When I turn on the anti Alias option, rendering time tends to increase substantially....
I guess if I want to get the good quality image then have to accept its downside too...
Thank you very much for all your helps....
Cheers
vxg139
Darboshanski posted Fri, 16 June 2006 at 1:08 PM
Quote - Don't use Texture filtering. It will eat up memory like crazy, and may do bad things to other textures in your scene.
Great link thanks!
BrokenAngel9 posted Fri, 16 June 2006 at 2:28 PM
Tsk, using Carrara for rendering makes you forgot the simplest things! What Randym said!
