ksabers opened this issue on Jun 21, 2006 · 3 posts
ksabers posted Wed, 21 June 2006 at 6:26 AM
I have tried to import a .PZ3 scene into Carrara 5 Pro using Transposer 2. It seems to load OK, except for the point of view. That is, when I look at my objects with Carrara, the camera is not where I had leaved it in Poser.
Is there a way to import the camera positions too? Or I have to place them again manually?
Thanks,
Giorgio
Morgano posted Wed, 21 June 2006 at 8:29 AM
I don't know of a way to import the camera positions along with the rest. The Carrara cameras don't correspond exactly to the Poser cameras, so I think you have to start again with the Carrara ones.
bigjobbie posted Sat, 24 June 2006 at 5:38 AM
Yeah, I was trying this myself - it doesn't work out too well.
My best idea is to rig up a primitive object in poser to sit exactly over your camera (a cone or cylinder) so you can put a C5 camera in the same place once you've imported the scene.
Remember to write down your lens angles etc as well and use C5's "zoom" slider to match the numbers.
Cheers
