jackhalsey opened this issue on Jun 23, 2006 · 5 posts
jackhalsey posted Fri, 23 June 2006 at 3:49 PM
I need to export a bmp or tiff from poser and when I do it has the wording "camera 1" at the top left and the lines which represent the ground on the background movie as I am exporting a still from a preshot avi..Got the ground lines out but still have the camera 1 wording...any advice and thank you.
Victoria_Lee posted Fri, 23 June 2006 at 4:01 PM
Be certain you're exporting your render and not the document window itself.
Do a render and then click on the File menu and select Export; then select Image and the program will prompt you for a type (jpg, tiff, bmp).
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
jackhalsey posted Fri, 23 June 2006 at 4:09 PM
So I would have to render first before I can export a still? Please advise and thank you.
diolma posted Fri, 23 June 2006 at 4:20 PM
Yup, you need to render 1st.
The "preview" window is exactly that - it shows you a (degraded) version of what the render might look like. Render, then export...
Cheers,
Diolma
jackhalsey posted Fri, 23 June 2006 at 5:28 PM
Thank you both.
