TwoPynts opened this issue on Jun 24, 2006 ยท 10 posts
TwoPynts posted Sat, 24 June 2006 at 2:05 PM
Perhaps one have you who own a large format Epson printer have run into this problem: "After printing an image on my R1800 that had a lot of lines in it, I tried using the Epson Printer utility to clean the print heads. In the middle of that test, it just stopped and said it could not be completed. Both the paper feed and ink lights are flashing in unison. I removed the paper and restarted the printer, but they keep flashing and I get no response from pressing anything other than the power button. The troubleshooting guide was not able to help. The printer is less than a year old. More data: Step 1 WHICH MODEL ARE YOU USING? Stylus Photo R1800 Step 2 What were you doing when the problem occurred? Printing Step 3 What happened when you tried to print? No response from the printer (printer just stopped printing) Step 4 What is the power light's current state? Flashing Step 5 What is the ink light's current state? Flashing Step 6 What is the paper light's current state? Flashing Step 7 WHAT IS THE PRINTER'S STATUS? Cover open or paper jam Step 8 The printer lights indicate that the printer has a paper jam or the printer cover is open. Before you can print, you'll need to fix the error. Would you like help fixing this error? Yes Step 9 Close the printer cover. Does that fix the problem? No Step 10 Turn your printer off and on. Does that fix the problem? No Step 11 Where are you loading your paper or CD/DVD? In the sheet feeder Step 12 Clear jammed paper. Does that fix the problem? No Step 13 Does the paper you're using meet your printer's specifications? Yes Step 14 Reload your paper using the instructions below. Does that fix the problem? No Step 15 Make sure the output tray is open. Does that fix the problem? No Step 16 Which operating system are you using? Mac OS X 10.2.4 or later" Any help would be appreciated, thanks.
