Forum: Vue
Subject: Rendering in Vue5
persius opened this issue on Jun 27, 2006 · 3 posts
persius posted Tue, 27 June 2006 at 10:51 AM
Greetings to all.
I have an issue with rendering in Vue5 Infinite.   I had the computer rendering all night only to discover that with 110 frames left to go, the system stopped. I had to abort the render.  Having said that, the renderer was creating a quicktime movie. However, this seems to be the problem.  How can I set up Vue's renderer to create individual frames?
Any input will be greatly appreciated.
Thank you.
stew451 posted Tue, 27 June 2006 at 12:38 PM
Under the animation render option screen for file type select browse and the save as type select either .jpg or .bmp and the loacation.  when you render it will put the whole animation in picture sequence, numbered and all.  Hope this helps.
thundering1 posted Fri, 30 June 2006 at 8:36 PM
You can also use the Targa format for your animation - and when you open them (they're uncompressed individual frames) in your NLE you'll simply open as a numbered sequence.
Hope that helps-
-Lew ;-)
