barrowlass opened this issue on Jun 28, 2006 · 10 posts
barrowlass posted Wed, 28 June 2006 at 2:23 AM
I've worked both with PSP9 and now PS7 to create Poser textures. I'm really getting into PS now as its capability to handle large files seems to be superior to PSP. However, there's one little niggle ........
In PSP if I duplicate a layer (say half face image) and want to mirror it - I just go to edit - mirror and voila! However, in PS if I go to edit - transform, flip horizontal, the image flips, but I have to manually drag it to where I want it to be.
I'm probably missing something really fundamental here, but would welcome any help
Sheila
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
tantarus posted Wed, 28 June 2006 at 4:10 AM
First trim the document canvas in image-trim, so that head edges are at very end of canvas. Select whole head and press CTRL+J to copy it on new transparent layer. Delete half head and duplicate the layer, flip it horizontal. Click on Background layer and make sure that you have move tool selected. Link it with fliped face layer and you`ll have align options bellow the menus. Its not fast way, but I hope it will help you :)
Tihomir
Open your mind and share the knowledge!
barrowlass posted Wed, 28 June 2006 at 4:13 AM
thanks! sounds a bit involved but I'll try it
keppel posted Wed, 28 June 2006 at 4:54 AM
Try this appoach.
You can turn this into an action by making your initial selection as in 1. above and then start recording your action for the remaining instructions 2 - 7. This way you can achieve a single click mirror like you are used to in PSP.
Shane
My Renderosity Store
Virtual Furnishing
My Portfolio
barrowlass posted Wed, 28 June 2006 at 9:45 AM
thanks keppel it's worked a treat! being relatively new to PS I'm still finding my way round - have saved this "action" for future use now - no more scratching my head!
Sheila
tantarus posted Wed, 28 June 2006 at 2:26 PM
Excellent way of mirroring keppel. Thats the fastest for sure :)
Tihomir
barrowlass posted Thu, 29 June 2006 at 8:53 AM
As I said before this is a great way of doing things, but I don't know how to save the action for future use - when I try, the "save action" option is greyed out
Sheila
tantarus posted Thu, 29 June 2006 at 2:23 PM
Here is the way of recording action. First click on little triangle in upper right corner to open drop down menu. I would sugest that you make "new set" and name it something like "my actions". Next click on new action and name it "Mirroring", select "my actions" set from set options. Click record and everything you do will be recorded under "mirroring" action. When you done with the work, click on "stop playing/recording" button in action palette. To check does it work, open some new document and select "mirroring" action from "my actions" set, and click on play button in action palette :)
Tihomir
barrowlass posted Thu, 29 June 2006 at 3:46 PM
thanks tantarus, will try that !
Sheila
keppel posted Fri, 30 June 2006 at 2:09 AM
This is a bit off topic from your original question being to flip a half of a face but if you take this process a step further and use you original selection and horizontal mirror and then mirror these two selections vertically you have a nice tileable texture.
Shane
Virtual Furnishing
My Portfolio
